« on: June 03, 2015, 08:25:20 AM »
this is a redo since we lost forum sections. when I first attempted the install I found out the lockers diameter was a bit to large so I had to do the following
ORW machined ID of ring gear to 4.63" and chamfered .015" off locker corner edge of ring gear so ARB would fit tight and bolt up. so if you are an automatic 2.0 99-05 with 4.88 gears this will work for rear only . Other than machining it was a standard install. i will attach linc from another Suzuki forum with additional
Just a Newbie crushing one rock at a time,2x4 rocksliders,lowrange 2"suspension lift 2" body lift and skid plates,5000 winch,towbar,grand vitara rear springs,100watt lights,ARB compressor /air up kit,ARB RD209 LOCKER,Roof rack,tow hitch, General AT2 255/70/15 or 31/10.5/15 Mud tires , 5.12 Gear swap,off road tent trailer,LED Lights
