Calmini EDSE Kit
  • 63 Replies
  • 24580 Views
Re: Calmini EDSE Kit
« Reply #60 on: March 27, 2016, 01:03:52 AM »
Yuri
Will you explain the suspension geometry improvements that were gained by building a link that is even longer than Calmini's 2nd generation longer link.
Do you mind explaining how you went about fabricating the longer link.
Did you modify the Calmini link?
I like the Orange color.
Curious what the story is behind all the vehicles being the same color.
Offline RJkick
  • 631
« Reply #61 on: April 12, 2016, 02:14:46 PM »
I tested the flipped shock and unfortunately I blew out the driver's side shock.
The rear shocks of a '95 Ford Aerostar seem to work best so far
Most likely am going to grind the middle of the upper arm gusset to see if I can get rid of the issue
More to follow
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 Nexen M\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
Offline RJkick
  • 631
« Reply #62 on: February 23, 2020, 10:05:44 PM »
Anyone with updates on the Kit
Mine is working really well with the exception of the shocks
Still trying to find a long lasting "desert running" shock
Offline RJkick
  • 631
« Reply #63 on: March 04, 2020, 12:04:48 PM »
Trying ProComp 9000
