newbie to the sami
  • 2022 Views
turbopower231
newbie to the sami
« on: November 18, 2012, 06:54:41 PM »
here is a pic of my new sami
93 with 93,00
spoa lift
30" discover sst
1.3 with cam and header
custom bumpers
rhino lined inside
Offline crewcabrob
  • 348
Re: newbie to the sami
« Reply #1 on: November 18, 2012, 07:55:37 PM »
Looks really nice.
Rob
turbopower231
« Reply #2 on: November 19, 2012, 07:12:19 PM »
thanks,need to gear it,for highway use, which is recomended, TC or R&P? any input would help. thanks
Offline crewcabrob
  • 348
« Reply #3 on: November 20, 2012, 06:10:46 AM »
I did the TC on mine to get hwy manners back.  It goes pretty well now with 32s on it..  I think its easier to do too, unless you plan on installing lockers anyway.  I didn't want to tear teh difs apart unless I really had to.
Rob
turbopower231
« Reply #4 on: November 20, 2012, 02:44:39 PM »
looked at lowrange off road,and 4.1.1 is recomended for 30" tires and 4.9.1 is recomended for 31 to 32". i hate to do the 4.1 in the TC then put bigger tires later.  think the 4.9 in the TC would be ok for 30",give me a little room to grow
Offline crewcabrob
  • 348
« Reply #5 on: November 21, 2012, 08:43:17 AM »
You are kind of in a hard spot working between what you have now and what you think you will end up with.  I knew I wanted to run 32s and not really go any larger.  That is why I went right for the 6.5 case.
I hate to do this, but I will give you advice based on what I would do.  I would go straight to the 6.5 gears now.  You will have lots more power right now, but it will be more correct when/if you upgrade down the road.
My speedo is still off by a wide margin with teh 6.5 gears.  I'm trying to figure out where the discrepancy is.
Rob
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« Reply #6 on: November 21, 2012, 09:34:28 AM »
I have the 4.91 tcase gears from low range. with 31" tires my speedo is/was dead on. I run 4000 rpm at 60mph in 5th. Install was easy with just a hammer and a vice. I do have prior experience doing things this way however. Make sure they send you the instructions.
Whats a guy gotta do to earn some respect around here?
turbopower231
« Reply #7 on: November 21, 2012, 02:44:00 PM »
did you guys re-use the stock TC brkt,or buy the fancy aftermarket one?
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« Reply #8 on: November 21, 2012, 04:20:24 PM »
Fancy bracket whether it needed it or not.
