Technical Discussion - Performance / Modify
axle swap ?
axle swap ?
willgivens18
axle swap ?
November 12, 2012, 12:07:05 AM »
I did a 4.3 v6 swap and the spoa lifted yj springs on my samurai. But my tire size was 30". I want to go to a 38". So my question is what axle combo will support this, or will the stock axles hold. I will mostly be in mud no major rocks.
Tan Zuk
562
8
Re: axle swap ?
November 12, 2012, 02:29:39 AM »
You can check out my build for a lift with 38" tires. I have the Toy axles with v6 thirds but I am running a beefed up hybrid motor. The Dana's way be a better option with a 4.3.
Link
http://www.zukiworld.com/forum/build-diaries-how-to-diy/zuk-on-38's/?PHPSESSID=b62fbfe56c6fb0ae656d9ab55f88ed76
Last Edit: November 12, 2012, 02:45:41 AM by Tan Zuk
willgivens18
Re: axle swap ?
November 12, 2012, 07:44:44 AM »
Well I just don't know if I should go with Dana 44, Dana 60. I plan on supercharging it in the future. If toy will hold then I could do that. Thanks for the help
AZuki13
53
2
Re: axle swap ?
Reply #3 on:
November 12, 2012, 09:43:04 AM »
Toyota axles are stronger than dana 44s. You could put some money into a set of toyota and they should hold up. Im not sure how hard its going to be to find a dana 60 with the drop on the correct side.
willgivens18
Re: axle swap ?
Reply #4 on:
November 12, 2012, 02:34:37 PM »
Since the swap I need the front hook up on the passenger side rear needs to be center. Also how easy will the swap be. I did the motor, transmission, and transfer case myself.
AZuki13
53
2
Re: axle swap ?
Reply #5 on:
November 13, 2012, 07:36:13 AM »
The swap is fairly easy. Are you going to use leaf springs of a 4 link?
willgivens18
Re: axle swap ?
Reply #6 on:
November 13, 2012, 10:31:41 AM »
I will use lifted yj jeep springs
AZuki13
53
2
Re: axle swap ?
Reply #7 on:
November 13, 2012, 10:53:40 AM »
theres a kit for it yj springs and yoda axles. But you can do it on the cheap with a little bit of hunting around for parts
willgivens18
Re: axle swap ?
Reply #8 on:
November 13, 2012, 01:31:56 PM »
I want to try and do it myself. I just want to make sure toy axles will hold the power and tires I want. I don't want to replace parts later. One and done at least I hope so.
AZuki13
53
2
Re: axle swap ?
Reply #9 on:
November 14, 2012, 10:36:27 AM »
yoda axles will hold up. any axle will brake if you're not carefull. Trail tough or lowrange offroad should have everything you need.
willgivens18
Re: axle swap ?
Reply #10 on:
November 14, 2012, 01:21:47 PM »
Ok thanks guys. I guess all I need to do now is get to work. I won't be TO hard on them. Toy axles it is.
