Rust is cheap thread locker...
and stud breaker.
I always use anti seize on lug studs. And get this, I only torque them to the recommended limit 80 ft lbs. I know it seems low compared to those air wrench jockeys at most tire shops, but why would they give a shit if your stuck on the side of the trail and can't get your lugs off because their too tight. I've seen some shops use max torque on an air gun putting as much as 200 lbs on a lug nut. Then I've also seen tire techs at Costco use a torque wrench! at factory settings ! Go figure. Anti Seize rules
![laugh :laugh:](https://www.zukiworld.com/forum/Smileys/aaron/laugh.gif)
Screw " them. "
