Hawk 260 torque cam question!
  • 18 Replies
  • 3955 Views
Re: Hawk 260 torque cam question!
« Reply #15 on: November 15, 2012, 04:53:22 AM »
4" Suspension lift, but it's maxed out IMO. I've got only a couple inches of droop in the front and am using ALL the travel in the struts ( OME with a 1.5" spacer ) + limit straps to prevent over extension, with modified stock control arms, 16" FOA 550 lb coils with a bit of trimimng to fit the coil pocket in the control arm which has be cut and re-angled.. In the rear FOA 16" coils, Doetch Tech shocks with modified upper and lower mounts. Both ends have had the Hagon trreatment. Rides real nice though and handles terrian very well.
Can't wait to see how you engine build works out.
Offline KJMac
  • 280
« Reply #16 on: November 17, 2012, 09:38:49 PM »
Bentparts,
Great info as usual! Where did you get your springs? I think I'm going to get new springs for mined at least the front.
I have had an MS relapse so I haven't been able to touch it, I will be sure to let you know how it runs!
Thanks!
« Reply #17 on: November 18, 2012, 04:20:35 AM »
I got my springs from Suspension Specialists, but they can also be had from FOA, I believe their in Nevada. Sorry to hear about your MS. I used to build Custom wheelchairs and some of my clients had MS. I hope yours never gets that bad.
Offline KJMac
  • 280
« Reply #18 on: November 19, 2012, 01:01:52 PM »
Thank you Bentparts
I hope mine doesn't get that bad too, I use a cane now but when it flares I don't get areound good. That is cool you built custom wheelchairs! That must have been fun and rewarding! I will check out the websites you listed. Thanks
