Technical Discussion - Performance / Modify
Weber carbourator problems
somersetzuk
14
November 04, 2012, 01:11:21 PM »
Cant seem to adjust it just right any tips or secrets to these things. my problem is hit a bump an it will kill out i can pull up my drive way an it will kill out. any help will help me out thanks.
rascott
669
15
tread lightly monkeywrench a little
Re: Weber carbourator problems
November 04, 2012, 09:45:18 PM »
perhaps the float is set too high.
uphill may pour gas into venturi, if this were the case. mabe bumps too.(?)
have you looked inside it before?
32/36 weber?
Capt
738
28
LIFT IT ! .......Fat Chicks CAN'T JUMP !!
November 05, 2012, 09:02:28 AM »
Is It Really a WEBER?
Stock Hitatshi carbs will do this when the Metering & Shut off solenoid is going south.
It is a NON-REPLACEABLE part. Only option is to get a different carb.
Haven't heard of a Weber having this problem.
somersetzuk
14
Reply #3 on:
November 06, 2012, 01:24:12 PM »
IT IS A 32/36 weber SO I DONT KNOW I HAVE HEARD I NEED TO BEND MY FLOATS
rascott
669
15
Reply #4 on:
November 06, 2012, 07:29:59 PM »
i still think it would be worth opening it up and checking the float set.
you mentioned it cuts out going uphill?
