All good suggestions guys, especially like the " tubing " cooler addition one. Frankly, I really don't think I need a PS cooler, been running this truck without one for almost 6 years with no ill affects. If it wasn't for the leaking seals the old one would still be in there. I'm trying to simplify, adding external oil lines for cooling just makes for more shit to go wrong, and with my luck it probably would. ( We are in the middle of a hurricane, all businesses are closed, roads closed to the public AND MY FRIGGIN WATER HEATER JUST TOOK A SHIT AND IS LEAKING!!! I WON'T BE ABLE TO FIX IT UNTIL THE STORES OPEN UP AFTER THE STORM. NOTHING TO DO WITH THE WEATHER, JUST BAD TIMING AND MY LUCK. GO FIGURE
The res thing, well I just don't like leaks. It's such a small amount it only looks a bit shiny around the seam, but gobbing it up with JB weld, even though it would probably stop it just isn't my style. I know it would work, have done it on other jobs, but no JB this time. I bet ya Sky, you could probably make it look good too.
I never took into account how the tank itself could act as a heat sink. I think that with a third more oil in the system though any deficit in the tank cooling itself would be a wash. If the plastic tank is not up to the demands of a 4WD, why would they put one in a 4WD Isuzu trooper? I don't have any reservations about the tank being plastic, and for $5 the price was right. I've seen fancy billet aluminum ones for way over 100 bucks, but this aint no show car.
If it fails somehow, I'll let you all know so I can be publicly ridiculed
