Tracker Half-cab.
  • 23 Replies
  • 9805 Views
0 Members and 14 Guests are viewing this topic.
Offline Cheeto
  • 55
Tracker Half-cab.
« on: October 23, 2012, 11:07:14 PM »
Winter's coming, my soft-top is in need of repair and I can't find a decently priced hard top...what to do? How about pull all the seatbelt hardware (pulled the rear seat the day I bought the Tracker), soft top bows and plastic trim and make a half-cab!
 Several nights of brainstorming, some 1/8" diamond plate aluminum, a jigsaw with a bunch of metal blades, a buddy at a glass shop, a couple of door seals from a Peterbilt, a buddy that can weld aluminum (although a drill and bolts could be substituted), misc. hardware, some tweezers to remove aluminum slivers, some gloves to avoid more slivers, a patient and helpful girlfriend and this is where I'm at.
Offline Cheeto
  • 55
Re: Tracker Half-cab.
« Reply #1 on: October 23, 2012, 11:12:24 PM »
I need to pull it off again when I have some free time and clean up the edges. Long term plan is for it to become some shade of black...it's too bright as it sits. Also need to get a piece of angle welded underneath to mount a seal for the tailgate. For now I have a piece of foam pipe insulation filling that need.
Next up...A-pillar light mounts!!!
Offline Tan Zuk
  • 562
  • 8
« Reply #2 on: October 24, 2012, 12:15:28 AM »
Nice looking work 8) 8)
« Reply #3 on: October 24, 2012, 07:43:10 PM »
Looks really close to Drone637's White Rabbit build.  http://www.zukiworld.com/forum/build-diaries-how-to-diy/project-white-rabbit/30/
He used 1" angle across the back (mounted to the body) for deck support and to close the door up against.
How about some information on those headlights?
Offline Cheeto
  • 55
« Reply #4 on: October 24, 2012, 09:30:37 PM »
Thanks Tan Zuk.
Wish I had seen Drone's build before I got into this. I searched all over for any and all half-cab pics for inspiration....clearly I skipped the "Build Diaries" section. ???
RE: Headlights. The Tracker was wrecked when I bought it. The entire left front corner was gone. Angle iron made a framework that supports junkyard fender/hood/grille.  I wanted HIDs and had a kit with H3 bulbs. I get good deals from the Peterbilt dealer here (former employee and I left on good terms) so I bought some rubber bodied flood lights. Swapped out the sealed beams for a driving light kit made for Harleys (Yamaha uses the same exact style light) because it takes an H3 bulb. Light output is fantastic and current draw is less than halogens.
 The downside to these is the beam pattern. HID bulbs are longer than the H3 bulbs they replace so they sit in the reflector wrong. Add to this the fact that I have no high beams right now and the other driving lights on the bumper are useless. High beams were going to go in where the turn signals are now but I'm re-thinking that. 12" strip of amber LEDs sitting on the shelf waiting to take over marker/turn signal light duties. I have an extra set of projector driving lights from my Ram that will likely replace these low-beams when I get the bulbs. They take an H1. Bulb dimensions are much more comparable there.
 I have 2 more H3 HID kits. Thinking I'll test them in some 6" KC Daylighter style housings to see how they perform. I can then mount those either in the headlight area or on A-pillar mounts I plan on getting fabbed up some time soon...I hope. As long as I'm careful with how high up the A-pillar I go they will safely be under the legal headlight limit for Washington (54"). I gotta get something done because I found myself in the woods, in the rain, in the dark, cursing again! I hate not being able to see way down the road.
Sorry for the long-winded reply...I'm a details type guy.
Offline Cheeto
  • 55
« Reply #5 on: October 24, 2012, 09:42:27 PM »
« Reply #6 on: October 25, 2012, 06:59:05 AM »
Crap! Here's another half-cab I didn't see before.  :P
http://www.zukiworld.com/forum/build-diaries-how-to-diy/suva%27s-homeade-hardtop/msg194450/#msg194450
I like the back window in that one, and yours is better than Drone's, and he plans on making a larger window.
Where in Wa.?  I am up in Bow, and Drone is in Seattle with his rigs up at my place.
Offline Cheeto
  • 55
« Reply #7 on: October 25, 2012, 10:28:29 AM »
 A large window was a must for me. I feared this half-cab would make the interior feel cramped but that is not the case at all. Sheet-metal guy said to leave a 4" perimeter to maintain strength of the panel. I hit the inside with 80 grit and the glass guy bonded the glass right to the aluminum. No need to try to find just the right sized seal that way.
Any farther East in WA and I'd be in Idaho. Seems there's a real good following for these trucklets on the West side.
Offline beagle..t
  • 1239
  • 16
« Reply #8 on: October 25, 2012, 08:31:18 PM »
nice work
« Reply #9 on: October 25, 2012, 08:39:37 PM »
On mine it's just smoked plexi with double sided tape.  It will probably get bigger so I can use the rear view mirror properly this winter.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #10 on: October 31, 2012, 08:15:57 AM »
Dude!  Nice work.  And BRD HNTR beat me to it---I like the lights too.  I was going to do something like that on the other Tracker with the messed up front end but I sold it...yours looks like it turned out great.  Kudos
Offline talonxracer
  • 1284
« Reply #11 on: October 31, 2012, 09:57:49 AM »
I have started my own 2 piece bed cover/cab bulkhead on a spare kick body. It currently isnt that far along, I have the foam panels cut and hot glued in place for shaping, it will be then be covered with Solarfilm, waxed and a mold pulled from that. I will make the useable part from 4 plys of 8.4oz sqyrd 5 harness Carbon fiber, a 1/2" PVC foam bulker followed by two more layers of carbonfiber, then bagged and post cured.
I should be able to tap dance on the cover with no issues at all.
Offline Cheeto
  • 55
« Reply #12 on: October 31, 2012, 10:31:44 PM »
US Composites? What resin do you use?
Offline Cheeto
  • 55
« Reply #13 on: October 31, 2012, 10:34:02 PM »
Thanks for the kudos guys. I'll try to get some close-up pics of the headlights.
Offline talonxracer
  • 1284
« Reply #14 on: November 01, 2012, 05:41:21 AM »
I use either MGS 285/287s or Jeffco 1307/3176, and my preferred fabric is from Hexcel and DIVINYCELL for a pvc foam sandwich core. I am also highly considering a safety layer of kevlar as the top and bottom ply so if it does shatter from an impact that there is no carbon splinters/shrapnel.
I really like that headlight setup!
« Last Edit: November 01, 2012, 05:46:34 AM by talonxracer »
