My first build...well kinda
  • 1750 Views
Offline jheuss77
« on: October 17, 2012, 09:56:00 AM »
 Well I was following the pier paul build, looking for ideas for this Tracker I had wrecked. I had all this money in new bearings breaks, axles, tie rods, blah, blah, blah, so in an attempt to not loose all the money I had tied up in this black one, and a wasted trip to Michigan on a supposed rust free one, I found this red one for $600 a mile away from mi casa. So I got it! The red one has a rusted shock tower and a bad driver door, best unmolested one I've ever seen though, but it's two wheel drive and sometimes it just shuts off and won't start (think it's a wiring issue), then sometimes it runs, The black one is four wheel drive and has never let me down, but it needs a new rearend. It has a bent driver side rear axle, which I hadn't discovered until I had repalce the rear bearings and axle seals and it was still leaking.
 So I want to repair the minor rust on the red one, bed line the tub, clean up and line the frame, swap drive lines, wiring, interior, dash, while installing a new clutch, timing belt kit, swap third members to use rearend and third housing off the red one since the factory powder coat is still in great condition, and if I can find a used calmini 3" lift kit (I've missed out on three now on CL). I want it used cause there is a budget and I want powder coat it, I don't want blue.
« Last Edit: October 17, 2012, 04:10:48 PM by jheuss77 »
96 Jeep XJ Cherokee 2dr sport 4x4 auto daily driver
95 Tracker 4x4 5 speed --wrecked
96 Sidekick 2wd Auto
82 VW Rabbit convertable 5 speed
Offline jheuss77
Re: My first build...well kinda
« Reply #1 on: October 17, 2012, 02:20:31 PM »
I came across a factory brushguard near Cleveland that I picked up for a $100 still in the package never assembled.
Some power mirrors froma local junkyard for $35
but I'm still looking for a driver side fender, 95 and newer stlye soft top some hard top clips for that hard top on the black one, I think it's a best top and the clips are no longer available.
I will have a few things I won't need too if anyones interested like a 2wd auto tranny and I have a complete 94 newer soft top and all clips and bars, newer style interior with air bags for starters, I will post a complete list later on in the classifieds section of this forum for those of you interested.
« Last Edit: October 17, 2012, 04:06:46 PM by jheuss77 »
