Technical Discussion - Beginner / Repair
no spark
no spark
Wilnailu
12
no spark
October 11, 2012, 04:43:34 PM »
1993 sidekick, I installed a good used engine complete,tried to start it will not start, checked with coil wire handheld to coil tower it will spark one time only.It has good fuel pressure,I already tried diff coil and dist,same crap,HELP
airdale navy
82
2
Re: no spark
October 11, 2012, 05:36:19 PM »
WHAT YEAR WAS THE ENGINE YOU INSTALLED?
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
Wilnailu
12
Re: no spark
October 11, 2012, 10:51:34 PM »
It is a 1994 1.6l 16v.I used all of the cars wiring harness except the injector section.The white plug back.
Drone637
8121
116
Evil Cow
Re: no spark
Reply #3 on:
October 12, 2012, 03:42:02 PM »
Unless you fried the ECM it sounds like a grounding issue. Check the distributor ground first them go from there.
Wilnailu
12
Re: no spark
Reply #4 on:
October 19, 2012, 11:31:35 PM »
after man hours a friend stopped by and in about 5 mins. found a broken wire going to the dist.Fixed it and it started and ran perfect.Thanks everybody
