t-case identity
  • 1532 Views
Offline Chitzu
  • 14
t-case identity
« on: October 03, 2012, 09:04:07 AM »
Hi all
Just started on my new old sammi,pulled the t-case drain plug and a drop of tarry stuff hung there so I pocked it and caught a gallon of nasty water on my chest.My question is I aquired another t-case but it has an E brake drum on back.Is this compatible to my 88 without drum?I would really like to have that E brake for better reverse hold.Thanks and a used work shirt to anybody that wants it.   Chitzu
 sammi
Offline jcowdin
  • 111
Re: t-case identity
« Reply #1 on: October 03, 2012, 10:12:45 AM »
I think you would have driveline length issues.  How much does it stick out compared to your old yoke?
The Price is Right!
Offline Boxcar
  • 936
Re: t-case identity
« Reply #2 on: October 03, 2012, 10:21:11 AM »
It's a pre 86. The flanges will be different . Worth the effort though. Shaft brakes are grate ..... Boxcar...
God Bless
Offline Chitzu
  • 14
Re: t-case identity
« Reply #3 on: October 03, 2012, 12:59:26 PM »
Thanks guys
I don't have the "old" one out yet but if pre 86 is not inheritantly bad then I can make the driveline work.
Free used work shirt,  Chitzu
 sammi
Offline jcowdin
  • 111
Re: t-case identity
« Reply #4 on: October 03, 2012, 01:17:39 PM »
I had taken my 92 Samurai's T-case and installed it into my 88 and yes the flanges are different but other then that it fit just fine.  If yours has a good lift, you may not even need to do anything with the driveline.  Since most people end up installing driveline spacers, may end up fitting perfect without any mods.
The Price is Right!
Re: t-case identity
« Reply #5 on: October 04, 2012, 01:46:02 PM »
If it has a drum on the back it is likely a SJ-410 t-case.  It will have a 10% gear reduction in high and low range over the stock Samurai t-case.
Offline Chitzu
  • 14
Re: t-case identity
« Reply #6 on: October 04, 2012, 05:55:53 PM »
 :)Thanks for the help,hope to have some time this weekend.The extra 10% reduction is nice but may not need it with the big 1.3 engine.I'll keep track of what it takes just in case somebody needs it.   Chitzu
 sammi
Re: t-case identity
« Reply #7 on: October 04, 2012, 06:06:59 PM »
One more thing, if you pull the drum brake off you can just bolt on your stock flange.
