newbie got a few ?
  • 1124 Views
newbie got a few ?
« on: September 29, 2012, 03:18:47 AM »
Hello everyone I have some questions first I have an 1995 Suzuki sidekick how can I find out what submodel it is.
Also where is best site to buy accessories and parts for it.
Lastly put a new clutch, pressure plate, and clutch cable and before it shifted real smooth now it is really hard to push clutch in and you have to just ram it as hard as you can to go threw gears. Sometimes its easier when you take of from a stop just turn Suzuki off put in 1st then start up and take off any help would be appreciated and more I learn I will soon return the favor thanks.
Re: newbie got a few ?
« Reply #1 on: September 30, 2012, 02:51:53 PM »
Usually on submodels you can tell which they are by....
2wd=JA
4wd=JS
power windows and locks=JLX
"leather" seats=Limited
There are other "options" that are usually included in JS, JLX and Limited models, other than what I listed above.  Sometimes the submodel designation is also on the tailgate.
For your clutch issue.  Sounds like the cable might be bad (it does happen on new ones, especially if it isn't a genuine suzuki cable).  If you still have your old cable around, swap it back on and adjust it and see if it shifts easy again.  I would not drive it with it shifting like it does now...you could cause damage that will cost a lot more time and money to fix.
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
« Reply #2 on: October 03, 2012, 09:43:36 PM »
are you looking to lift it or anything?
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
Offline jwarnick11
  • 46
  • Jeep? you know barbie drives one of those.
« Reply #3 on: October 06, 2012, 08:02:54 PM »
sounds like the cable is either bad or adjusted wrong. I had the same problem on my 94 when I bought it. I went through 3 cables before finally getting it fixed. good luck on that though
94 kick 1.6 16v
fully rebuilt motor with custom head work
doug thorley header
jeffs 2in spacer lift
30x9.50 on 15x8 cragers.
