1998 Geo Tracker Gears
  • 1819 Views
« on: September 12, 2012, 03:43:02 PM »
I am thinking of lifting a automatic 4 door tracker would I need to regear it to run a 31 inch tire?
Re: 1998 Geo Tracker Gears
« Reply #1 on: September 13, 2012, 07:29:20 AM »
There seems to a big difference between 30" & 31" tires in how much power is required.  I think you will want to regear to get some power back.  If you have a 3 speed auto you have 4.30's and could go to manual 5.12 gears, but if you have a 4 speed auto to get a lower gears you will need to find the rarer ones.  And they are usually pricey.  31" tires also require lift, messaging &/or modifications to keep from rubbing.
« Reply #2 on: September 14, 2012, 06:51:42 AM »
Since you have a 4 door, you will have 5.12 axle gears (the 4.30s only came with 3 speed auto trannys and a 16V and the 4 doors never used the 3 speed...all the autos in the 4 doors were 4 speeds).
So you will need to find a set of 5.38 or 5.62 axle gears.  Yeah, they can be hard to find and are usually pretty expensive, when compared to the common ratios.  I do have sets of each in the classifieds section.
