Note the one rib running down the right side of the housing. (on both the steel & alu)
This one appears to have two ribs.. (I found the pics via a google search, so they are not ideal, but you get the idea)
_______________________________________________________________
I used a thick rubber ring placed in between the air actuator and the dog clutch to keep my 4x4 engaged. I had initially tack welded the actuator in the engaged position, but I went about the welding all wrong and the welds broke out..
I welded the ring in place
before assembling the gear set (silly me), and it was welded 'pushed in' a little too much. So when I assembled everything and bolted the ring gear on, it placed excessive stress on the clutch and broke the welds back out.
I was forced to use a rubber ring because I needed the 4x4 urgently and could not get access to a welder at the time.
So far the rubber ring I used is holding out and I have not gotten any problems as yet.
