OK, I'm going to swear off the 33" tires right now. I will not go that big as I really don't want to break things. I do plan on 26 spline axles in the front as well as Chromoly in the rear when the ARBs are added, but still I don't want to break anything else in the driveline, frame, suspension, mounts, links... you get the idea.
OK, since I can finally narrow it down to 31-32s I'm getting closer on that. I'm still stuck on wheels, but I can figure that out as I go. Both size tires will work with an 8" wide wheel, I just have to decide weather I want to deal with the risk of running a tire off a rim when down at 8-10 psi. I've never seen someone lose a bead offroad in all my years offroading. I know it happens, but I always wondered if it happens more in wet condtions.
My springs are in rough shape and need to be replaced. I'm committed to new springs at a minimum along with other goodies for the lift: lines, spacers, shocks...
I just can't seem to find that sweet spot for height, ride, articulation and stability. I know the different lifts have different attributes and some are better than others for 1 or two of the aspects but not all. Where is the jack of all trades for my application?
Rob
