Anyone out there with experience modifying a sidekick 1.6 to cv carb
  • 1093 Views
Offline hwally
  • 22
I have the mods done as far as mounting the carb and installing a Samurai non-ecu distro.  I'd like some info on modifying the stock sidekick fuel pump.  I have an after market electric fuel pump but I need to hook up the inlet side to the gas tank.  Is it possible to modify the stock fuel pump unit so I can draw fuel from the tank?  Also on the Samurai distro.  it has two wires coming out of it  is one a ground and the other hooked up to the negative side of the coil?  Any help is greatly appreciated.
Offline AZuki13
  • 53
Re: Anyone out there with experience modifying a sidekick 1.6 to cv carb
« Reply #1 on: September 04, 2012, 09:21:13 AM »
The small ground wire on my sammy goes to the firewall. What carb are you running?
