Another locker question
  • 1102 Views
Offline showgun
  • 17
« on: August 25, 2012, 07:34:07 PM »
I purchased a samurai and verified today that it has 5.13 diffs. The rear end has a spool and I want to put a locker in for streetability.
Does the gear ratio matter when purchasing a locker or is it dependent on the axle splines?
Any input on where and what to buy?
thanks
Offline weldboy
  • 91
  • I'm only here for the carnival atmosphere !!!
Re: Another locker question
« Reply #1 on: August 25, 2012, 11:14:24 PM »
It doesn't matter the gear ratio, it's the spline count which is 26 and you can use a ARB or Lockright, or Spartan. You can get any of them at Low Range or Trail Tough. I love my mini spool it's much more predictable in turns, and who cares if the tires chirp going around corners.
Offline showgun
  • 17
« Reply #2 on: August 26, 2012, 07:09:29 AM »
Thanks for the info.
Doesnt the rear end being locked up put too much torque on the axle/gears when running on pavement?
« Reply #3 on: August 26, 2012, 11:12:44 AM »
yes it does, you have to over inflate your tires and not have too much weight on or in your rig.
Offline showgun
  • 17
« Reply #4 on: August 28, 2012, 05:08:42 AM »
Well, I went ahead and ordered a spartan locker for the rear end (along with other parts that my wife need not know about!) The sammy was already built for offroad only use when I got it, Now its time to update it with some new parts and make it a little more street worthy :laugh: Ill keep you guys posted as I go through it because Im sure I'll need some help with the axles, drivelines and lockers!
Thanks again.
