WTB: Clutch Pedal assembly for 1997 GEO Tracker(4 door 4x4)
  • 12 Replies
  • 10373 Views
Offline rluka
  • 26
« on: August 13, 2012, 02:49:22 PM »
My clutch pedal broke off. It had been welded before and would prefer not to re-weld.
Here is a picture of the whole assembly.
« Last Edit: August 26, 2012, 09:44:39 PM by rluka »
Offline rluka
  • 26
Re: WTB: Clutch Pedal assembly for 1997 GEO Tracker(4 door 4x4)
« Reply #1 on: August 26, 2012, 09:46:09 PM »
Are there variations of this assembly?
Offline talonxracer
  • 1284
« Reply #2 on: August 27, 2012, 04:49:47 AM »
Yes there are 2 set-up's, 95' and older and 96'-98'
I went thru two clutch pedals. The pedal always felt very stiff(went thru 3 cables as well), the cause I discoverd was the stock clutch cable retainer on the fenderwell. It holds the cable up and away from the exhaust mani, but this  amplifies the cable resistance several fold by forcing the cable into a slight "S" curve. I put a vacuum hose and then a heater hose over the cable near the mani/header and then wrapped it with header wrap to keep it from being melted by the exhaust, and didnt use the cable retainer, just a zip tie to the frame/body far lower,
« Last Edit: August 27, 2012, 04:52:58 AM by talonxracer »
« Reply #3 on: August 27, 2012, 05:59:18 AM »
There are actually 3 variations.  There were 2 versions in the 89-95 timeframe.  I don't recall when the break was in the earlier years, but I have read from reliable sources that there are 2 different versions.
« Reply #4 on: September 01, 2012, 07:36:44 PM »
Did you find one?
Offline rluka
  • 26
« Reply #5 on: September 23, 2012, 05:37:38 PM »
Did you find one?
Havent found one yet. This one have had already been welded so I had it welded again. I would like to find one that hasnt been welded.
 So, Im still looking
Thanks
Ron
Offline jeff1997
  • 1228
  • 27
« Reply #6 on: September 24, 2012, 12:48:16 PM »
I welded my 98 Sport 3 times. Each time it broke in a different place. I finally just refabbed the whole arm and it held up fine. Mine had the hydraulic clutch.
3" Masterkit1 body lift
Custom strut spacers
Offline rluka
  • 26
« Reply #7 on: September 30, 2012, 11:47:09 PM »
Im still looking for a part ... get in touch in you have one
Offline 1579
  • 18
« Reply #8 on: October 01, 2012, 04:29:04 PM »
I have one of these I just removed. It won't fit my 1995, that is for sure.
It's from a 1996 4dr 16v. Let me know if you want pics.
Or send me a text at 905-928-3499
Brandon
Offline rluka
  • 26
« Reply #9 on: October 15, 2012, 07:26:27 PM »
Brandon
Thanks..I'll give you a call
Offline 1579
  • 18
« Reply #10 on: October 24, 2012, 05:27:43 PM »
I'm new to youtube but here's a pretty terrible video of the clutch pedal assembly I have. Yes, I left them out in the rain, only for a couple of days tho!
Didn't think someone would be after these!
2012-10-19_21-04-45_460.mp4
Offline rluka
  • 26
Re: Khodabear
« Reply #11 on: October 30, 2012, 12:43:55 PM »
"Khodabear" ....... you sent me a private message...I responded but your mail box is full
Hope you see this
Have a great day
Ron L
Offline Khodabear
  • 155
  • Littleton Colorado
« Reply #12 on: October 30, 2012, 06:40:14 PM »
Are you still looking for this?
I'm dismantling a 97 Sidekick - should be your parts no?
1997 Tracker
1997 X90
