Thermostat and SoCal weather
  • 1231 Views
Online RJkick
  • 631
« on: August 06, 2012, 02:08:16 PM »
We really don't get too cold out here so I was curious if anyone runs without a thermostat in warm weather areas?
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 Nexen M\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
  • 4314
  • 167
Re: Thermostat and SoCal weather
« Reply #1 on: August 06, 2012, 04:34:59 PM »
The temperature where I am varies from a low in the high 70's to a high in the low 90's - is that warm weather enough for you - I would strongly suggest you not run without a thermostat, it's function is not related to the weather & the ambient temperature in any way - it's purpose is to get the engine up to operating temperature as rapidly as possible and keep it there - running cooler causes additional wear and fuel consumption.
« Last Edit: August 06, 2012, 04:37:47 PM by fordem »
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Online RJkick
  • 631
« Reply #2 on: August 07, 2012, 12:36:28 PM »
sounds like a bad idea to run without it so
Thanks and I'll keep it in
  • 4314
  • 167
« Reply #3 on: August 07, 2012, 02:49:55 PM »
Well - I've done it, and I'm in a climate where we never need heat - but the engine is definitely not happy like that.
In my case it was a beater that I had just had a sheetmetal thermostat cover fabbed up for, put it together with the stat and it leaked, so I tossed the stat - I only needed the car for another 90 days (had one in the bodyshop after a smackup), it was burning oil, leaking coolant, and just drinking fuel - but you know what - it got me from A to B - and I was sorry to see it go.
