my samurai trys to stall when i first give it gas
  • 1076 Views
« on: July 22, 2012, 12:08:20 PM »
My samurai tries to stall when i first push the pedal ,I have to pump the gas pedal to get the rpm over 2000 at this time it will take off fine.any ideas i can try would be appeciated.this is a 1987 JX model.
Thanks
Aaron
Offline kbeefy
  • 17
Re: my samurai trys to stall when i first give it gas
« Reply #1 on: July 22, 2012, 12:50:56 PM »
either accel pump not pumping or idle mixture too lean.
Offline weldboy
  • 91
  • I'm only here for the carnival atmosphere !!!
« Reply #2 on: July 22, 2012, 03:35:07 PM »
I had a similar problem after a 1500 mile road trip. Mine would idle smooth and would run with your foot to the floor but nothing in between. I found that the fuel bowl screws were loose from the carb base. I found I could twist the top of the carb from the base so, I removed the carb tighten the 4 screws and now it runs better than ever.
