4.30, 4.62, 5.12, 5.38, 5.62 gears/thirds
  • 15 Replies
  • 5261 Views
« on: July 18, 2012, 04:02:00 PM »
These are all stock trackick gears in stock trackick thirds, unless otherwise noted.  These are all open (no lockers, mini-spools, etc.)
4.30 gears/thirds for a samurai.
Two sets of 4.30 gears.
SOLD
4.62 thirds.
Both will have 22 spline sidegears. One bolts into the front of a samurai. The other has to have the samurai sidegears swapped into it, or the gears have to be put in a samurai rear third, in order to work in a samurai rear axle.
$325/pair (2 complete thirds) + shipping.
5.12 thirds.
These thirds will have 26 spline sidegears and will bolt into the back of a samurai, or the front of a 96-?? trackick.
$250 per third, plus shipping.
4.62 or 5.12 gears only (1 ring, 1 pinion.....no bearings, no shims, no flange).
You can bolt these gears into the front or rear third of your samurai, or they can be bolted into the front of any 89 to at least 98 trackick.
$180 per gear set (1 ring, 1 pinion) shipped to the lower 48.
If you want a pair of complete bolt in 5.12 thirds, I can do that too. What you will get is 1 stock trackick third that will bolt into the rear of your samurai and 1 stock trackick third that will bolt into the front of your samurai.
$425 + shipping, for a pair of bolt in thirds.
5.38 front and rear thirds for a trackick.
This is the last set of these I have.
The rear third has 26 spline sidegears, the front third has 22 spline sidegears. The rear third will bolt into any 89 to at least 98 trackick. The front will bolt into the front of any samurai, or the front of any 89-95 trackick. If you want to use the front third in a later (96 or newer) trackick, then you will need to replace the sidegears with 26 spline ones, or replace the passengers side axleshaft and the drivers side inner axle shaft with 22 spline ones, or swap the gears over to your existing third.
The rear third does have the ABS plug on it....so your existing rear ABS will continue to function. If yours doesn't have rear ABS, you simply don't worry about hooking anything up to the ABS connection...it wont affect anything.
$500 for the pair, plus shipping.
5.38 gears for a samurai.
One is installed in a samurai front third.  The other is just a bare ring and pinion.
Both are aftermarket gear sets.
Good condition, no chipped or broken teeth.  Nothing wrong with the gears, that I can tell.
$450 shipped, to the lower 48.
5.62, yes 5.62, front and rear complete thirds for a trackick.
These are hard to find gears....here is your chance to own some.
The rear third has 26 spline sidegears. The front third has 22 spline sidegears. The rear third will bolt into any 89 to at least 98 trackick. The front third will bolt into any 89-95 trackick. If you want to use the front third in a later (96 or newer) trackick, then you will need to either replace the sidegears with 26 spline ones, or replace the passengers side axleshaft and the drivers side inner axle shaft with 22 spline ones, or swap the gears over to your existing third.
$1000, plus shipping.
All of the above listed thirds and gears are in fine shape. Nothing wrong with them, that I can tell....the bearings turn smooth, the gears have no chipped teeth, no unusual wear patterns. Some gears/thirds are still in the trackick axle housings, so they will be pulled and checked for condition, once someone shows some serious interest in them.
All complete thirds have the pinion flanges that have the samurai large driveshaft bolt pattern (88.5-95), unless otherwise noted. The pinion flanges can be drilled for the smaller (86-88) samurai driveshaft bolt pattern. Either you can do it, by using your driveshaft as a template, or I can do it for some extra $$.  I do not recommend drilling a small samurai flange for the large bolt pattern, but you can do it at your own risk.
I will get shipping quotes only for people that are seriously interested. As a baseline, shipping generally runs $20-$40 per third to the lower 48 states.
US Postal Money Orders, or cash, for payments.
Located in the KC, MO area.
Let me know if you need more info and/or have any questions.
Thanks.
« Last Edit: September 14, 2012, 07:19:50 AM by Skyhiranger »
Re: 4.30, 4.62, 5.12, 5.38, 5.62 gears/thirds
« Reply #1 on: September 03, 2012, 06:27:21 PM »
Updated.
Offline mrdezyne
  • 181
« Reply #2 on: September 05, 2012, 08:02:26 AM »
interested in the 4.30's.  From what I can tell on the gear callculator, with my 6.5 tcase and 33 tires, these 4.30 will bring me closest to stock high gear speeds correct?  any adverse affects I'm not considering?
« Reply #3 on: September 05, 2012, 08:10:55 AM »
Yes, that is the ratio that will get you closest to stock high range RPMs.  It looks like it will actually get you slightly higher than stock RPMs at a given speed, but that is generally a good thing, since you are running tires with more mass that will be harder to keep spinning.
Offline mrdezyne
  • 181
« Reply #4 on: September 05, 2012, 08:35:36 AM »
Can you check shipping to 74147 and this will be a business shipping dock so that usually makes it a little cheaper...
« Reply #5 on: September 05, 2012, 08:49:42 AM »
PM sent.
« Reply #6 on: September 14, 2012, 06:54:26 AM »
4.30s SOLD.
« Reply #7 on: September 14, 2012, 08:34:03 PM »
How many sets/thirds of the 5.625s do you have? Negotiable? Any idea of the mileage as they'll be run on daily drivers?
Basically, we don't need them but want them if the price is right... ;)
Please PM me if the answers are 2 sets, yes & with some kind of assurance/guarantee. (yeah, I know)
-black '92 Samurai, bought new
-black '93 Sidekick, tintop
« Reply #8 on: September 14, 2012, 09:21:33 PM »
I have one set (front and rear for a trackick) of 5.62s left.
Price is firm...I don't have to sell them.
They are actually still in the sidekick.  The sidekick is non-op, so all I can do is look over the gears, once I pull them, to make sure there is no visible damage, and also spin them by hand, to make sure they turn smoothly.  If they pass those 2 checks, then all I can say is they are good.  I have sold many, many thirds and they all get checked this way.  I have never had any that passed these checks that were bad.  I have had some that didn't pass these checks and they did not get sold, of course.
The mileage on the sidekick is 71318 miles, which I believe to be actual.
« Reply #9 on: September 29, 2012, 11:39:21 PM »
Shipping on the 4.62 thirds to 76031? These good for stock transfer case running on 31 tires?
« Reply #10 on: September 30, 2012, 06:52:19 AM »
PM sent.
Offline SIDEKICK65
  • 176
« Reply #11 on: October 06, 2012, 05:42:23 PM »
I need 5.38 gear's but i need the rear from a sidekick and the front 3rd member from a samurai.can you hook me up buy doing this and if so how much?
« Reply #12 on: October 06, 2012, 06:23:31 PM »
The sidekick 5.38s that I have listed for $500 will work for you.  The trackick front third from that set will fit in a samurai.  But if you are wanting the samurai front third with 5.38s in it, from the $450 set, then I guess I could do that.
So trackick 5.38 rear third from the $500 set and the samurai 5.38 front third from the $450 set.....$600 + shipping.
Offline SIDEKICK65
  • 176
« Reply #13 on: October 07, 2012, 12:21:25 AM »
Will the front ring & pinion from the sidekick fit into a sami 3rd member?
« Reply #14 on: October 07, 2012, 06:05:39 AM »
Yes.
