1987 samurai 5 speed trans problem helpppppp!!!!!!
lilredsami92
11
July 14, 2012, 12:00:27 PM »
ok so my sami will not go in to any gear with the motor on or off have no clue what it wrong pls help?
if u cant find 'em, grind 'em!!!!!!!!!!
kbeefy
17
Re: 1987 samurai 5 speed trans problem helpppppp!!!!!!
July 14, 2012, 12:18:41 PM »
how sloppy is your shifter? I'd guess either a worn out/broken shifter+sheet(bushing) or something internal broken. Pull the shift lever and check it out.
lilredsami92
11
July 14, 2012, 12:26:27 PM »
it will go side to side but around 3rd and 4th gear it catches on something also i dont really kno what to look for
tuxblacray
930
20
Building a Bigger Better Brute Samurai.... B-}
Reply #3 on:
July 14, 2012, 12:37:59 PM »
This is most likely your problem and the cure....
http://www.zukioffroad.com/Tech_Library/transmission_shifter.shtml
I know the voices aren't real.... but they have some pretty kewl ideas!!! Tux..... ;-)
I get my Sammi parts here, and you can too...
http://www.mikodaindustries.com/http://stores.ebay.com/sticksnstones4x4samuraiparts
lilredsami92
11
Reply #4 on:
July 14, 2012, 12:42:15 PM »
ok thanks ill be working on it again tomorrow so ill chech it out tomorrow
lilredsami92
11
Reply #5 on:
July 15, 2012, 10:53:28 AM »
ok so i got it to go into gear but when i let off the clutch it doesn't move
