Parting Several TracKicks
  • 34 Replies
  • 5042 Views
Offline Khodabear
  • 155
  • Littleton Colorado
« on: July 08, 2012, 08:49:41 AM »
This consolidates two previous posts and adds 2 other vehicles to the list.
These are mostly rust free Colorado trucks - located in Denver.
1991 2 door: Most everything available except the motor and front clip. The tub and chassis have been scrapped.
5 speed with transfer case $195, ECM $75, nice set of factory alloy wheels $95, doors, glass, fuel system, top hardware, interior parts and much more.
1994 Sidekick 4 Door
: 16 valve, 3 speed Automatic. No air :-(
For those who've asked about the head - it's coming off in the next day or two. Vehicle is complete with a very straight rust free body. If the title wasn't screwed up this would be a candidate for rehabilitation.
1994 2 door: 1.6L 8 valve. Hear it run! $595 complete plus any and all wiring you need , 3 speed automatic transmission $150, 4.30 thirds (They haven't been pulled so I'm going off specs)$295 for for both. Some body parts.
1997 Sport Sidekick 4 door 1.8 L. Good motor $695, all body and interior parts, ECM $100, AC parts, Power Steering. This one suffered transmission failure - other than that it's straight and complete.
Offers considered - the more you buy the better the deal :-)
303 91 eight 944 five
Email Finboats|removethispart||removethispart||removethispart|@Gmail.Com
« Last Edit: July 10, 2012, 06:59:18 PM by Khodabear »
1997 Tracker
1997 X90
Offline krittergitter
  • 114
Re: Parting Several TracKicks
« Reply #1 on: July 10, 2012, 06:37:06 PM »
Just a little help here, your 96 should have 16 valve motor.
Offline Khodabear
  • 155
« Reply #2 on: July 10, 2012, 06:58:51 PM »
You're right! The 8 valve is a 94.
I also have a '96 two door that has one weak cylinder. I'm not yet certain which direction to take with it as it's actually a fairly nice little rig. So I've not committed to parting it - but it's on my mind.
Thanks!
Peter
« Last Edit: July 10, 2012, 07:00:25 PM by Khodabear »
1997 Tracker
1997 X90
Offline zuki709
  • 190
  • 6
« Reply #3 on: July 11, 2012, 05:20:27 AM »
how much would you want for the ring and pinion front and rear out of the 97 sport?
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
Offline Khodabear
  • 155
« Reply #4 on: July 11, 2012, 05:49:11 PM »
This is difficult. Needless to say selling these would take it off its feet and I'm not a pro yard with a forklift. So it would have to be the last items I'd sell off of  it. Since this is the functional equivalent of selling the whole thirds I'd have to say $345 plus postage for both.
1997 Tracker
1997 X90
Offline airdreams1
  • 90
« Reply #5 on: July 11, 2012, 09:21:07 PM »
 "3 speed automatic transmission $150"
any idea on shipping to star ID 83669
87 Samurai  soft top
Offline oneal
  • 38
« Reply #6 on: July 13, 2012, 02:19:07 PM »
 Do you have the retractable seatbelt for the drivers side rear(just need the belt/retracter not the whole assembly.Also need a driver door cable that operates the window(manual)
Offline Khodabear
  • 155
« Reply #7 on: July 13, 2012, 05:30:10 PM »
I replied before the outage but you might not have received it.
I have no idea - it would seem that a common carrier would have to be used.
If you care to pursue that please do so knowing that I'm happy to facilitate by palletizing and dropping it off at a shippers local dock.
1997 Tracker
1997 X90
Offline Khodabear
  • 155
« Reply #8 on: July 13, 2012, 05:31:57 PM »
The seat belt part is available - the drivers side window...I'll have to open the door up and see how it is. The window is a bit sketchy but it does work.
1997 Tracker
1997 X90
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #9 on: July 15, 2012, 03:24:16 PM »
What would you want for the driver and passenger seat belt floor to female clip button portions? (I don't need the upper male belt or re-tractors.
I put a Tuffy locking console in my Sammi and the side mount belt clips are just plain awkward.
Shipping could be both items in a flat rate USPS box. Area code is Indiana 47240.
« Reply #10 on: July 15, 2012, 04:55:53 PM »
Just an FYI....
4 speed autos are found in 4 doors.
3 speed autos are found in 2 doors.
So if that 94 is a 4 door, like you list, then it will have a 4 speed, not a 3 speed.
Offline Khodabear
  • 155
« Reply #11 on: July 15, 2012, 05:29:08 PM »
Just an FYI....
Shows you what I know  ::)
Thanks for the correction!!!
1997 Tracker
1997 X90
Offline Khodabear
  • 155
« Reply #12 on: July 15, 2012, 05:38:41 PM »
$20 plus postage I'd like to think they'd fit in a medium FRB for $11
Photo attached to be sure this is what you mean
1997 Tracker
1997 X90
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #13 on: July 16, 2012, 11:44:10 AM »
Yep that is them. I am gonna try to switch mine from side to side which will reverse the button location 1st. If that doesn't work out I will be in contact.
        Thanks, Tux...
Offline airdreams1
  • 90
« Reply #14 on: July 20, 2012, 11:42:56 AM »
ou have pm on the 3 speed trans....
i know ill need the trans, shifter, linkage, torque converter & ?
(if anyone kn0ows what else is needed to put it in a sammy please pm me.)
87 Samurai  soft top
