Carbarator Woes
  • 1721 Views
Carbarator Woes
« on: June 13, 2012, 01:41:33 PM »
I have a stock 88 1.3 carborated motor.  I cannot get it to stay ideling properly.  No matter how i adjust it.  It either idels too high or it wont start, or it will start and idel fine for a while, and then it will start dieing every time you come to a stop.  It is driving me crazy.  I have never seen a carborator with so many vacuum lines, and obviously i cant adjust this one.  My shade tree friends wont touch it.  The carb has all sorts of vaccum opeareated things that i dont understand look like some sort of choke system.  Any one of them could be bad.  Bought a Chilton book and can't make heads or tails out of it either. I have looked into a weber carb, but hear that the Harley although more expensive are better performers.  I have a Harley mechanic at my disposal, so i may go that route.  What do i need to buy to make the swap, and will it be less complicted then? what happens to all the vaccum lines?  I may have something simple wrong with mine any suggestions?
Re: Carbarator Woes
« Reply #1 on: June 13, 2012, 04:12:43 PM »
The most common issue with the stock Hitachi carbs is due to a vacuum line issue.  If you want to try and get the stock one running correctly I would go pick up some new vacuum tubing and replace all the lines, if they look like they need it or not.
For running the Harley Side-Draft carb ZOR offers a great kit in the MySide.  You can also make up your own conversion if you have the time.
Offline WesP
  • 40
Re: Carbarator Woes
« Reply #2 on: June 13, 2012, 08:07:07 PM »
I agree with replacing all the vacuum hoses. This link will help make sure all the hoses are going to and coming from the right places.
http://www.acksfaq.com/Samvacuumlines.htm
Re: Carbarator Woes
« Reply #3 on: June 15, 2012, 07:23:21 AM »
Thanks guys.  I will start with the vacuum lines if that doesn't do the trick, then its off to buy a Harley side draft kit
Offline mnrsamuel
  • 14
    • Samurai
Re: Carbarator Woes
« Reply #4 on: July 14, 2012, 12:41:43 AM »
I am experiencing similar issues, but my carb is a Aisan - see pic - also has lots of vacuum pipes, water hoses running through it and vacuum devices.
I found that replacing all the vacuum pipes, and the water hoses certainly did improve my performace and fuel consumption, but ultimately a carb rebuild will resolve the issue.
I also replaced my spark plugs, cleaned out the distributor / rotor, set the timing, did and engine coolant flush as well.
Take a look at my posting on the forum...
http://www.zukiworld.com/forum/technical-discussion-beginner-repair/high-rev-when-normal-operating-temperature/
--samuel
Offline Jakezuki
  • 21
Re: Carbarator Woes
« Reply #5 on: July 14, 2012, 03:21:13 AM »
if you start the truck up and take a can of carb cleaner and spray it on 1 vaccum line at a time u can pinpoint ur problem line
