Hagen Front-end Widening Guide
  • 13 Replies
  • 2953 Views
Offline explosivo
  • 3157
« on: April 13, 2004, 05:19:51 PM »
So I've read through the front-end IFS widening guide in the archived section, and I am kind of confused... It tells how to drill the holes in the back mount, but doesn't say anything about the front... wtf... Do you just do the same thing to the front control arm mount that the guide says to do to the back?
Also, rather than using the washers suggested in the guide, would some plate work? The only thing you'd have to change to do that is use some longer bolts, but it seems that using some 1/8-3/16" plate rather than washers would give a more solid mounting point...
omghi2.us[/url]
Re: Hagen Front-end Widening Guide
« Reply #1 on: April 13, 2004, 05:29:28 PM »
Just the rear holes get re-drilled, this moves
the wheel out and front, now the front CV cups
need to be addressed, I did my CVs different than
Mike, but they work.
Offline explosivo
  • 3157
« Reply #2 on: April 13, 2004, 05:33:15 PM »
Ah... got it. Thanks.
Please elaborate, and pics if possible.
omghi2.us[/url]
« Reply #3 on: April 13, 2004, 05:45:26 PM »
This is the best closeup I have of the Right side CV
cup extension, I used a piece of 3" DOM about ohh
2.5" long, cut the cup off and added it on, this won't
work for the drivers side, I had a 1" spacer made for
the Left side, I'm going to redo these but for now I
would say I got 20,000 Miles on the trucklet since I
did the mod, and about 1000 4 wheel drive miles.
Offline explosivo
  • 3157
« Reply #4 on: April 13, 2004, 05:49:11 PM »
So you didn't do the Explorer CV shaft deal... wasn't that the original intention of widening was to get bigger CV shafts to fit in?
Plus wouldn't it've been more convenient to do it the way the guide shows, so that CV's have the 3-bolt flange on each side?
Also, you widened the front end, did you do anything to the backend (ie: the 9" swap)?
« Last Edit: April 13, 2004, 05:51:13 PM by explosivo »
omghi2.us[/url]
« Reply #5 on: April 14, 2004, 04:11:37 AM »
I guess, it's been over 2 years since I did this mod.
Really it allows 33s with out much rubbing, if you want
35s you need to move the foot well back, Explorer
CVs are Mazda, so if you want, go dig up some parts
and swap out, I like the trucklet Suzuki, if I start blowing
parts every time I go wheeling, I guess I'll build some
stronger parts, but for now it's all holding together fine,
I have had minimal destruction of stock parts, and I know
how to trial fix it anyhow.
Ford 9in rear, I don't need it yet, someday maybe. I'm
working on ideas and stuff to solve the problems while
keeping the trucklet Suzuki
Offline 1bigtracker
  • 3409
« Reply #6 on: April 14, 2004, 09:57:08 AM »
ya i hate it when people put so many parts from other brands on the zooks, they'er not even zooks anymore.
stu
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #7 on: April 14, 2004, 10:02:31 AM »
WILD, I BET IT FELT GOOD TO KEEP UP WITH ALL THE HIGHLY MODDED $$$ RIGS  WITH YOUR LOW BUDGET CRAFTINESS AT WORK  ;D.  MATTY D.  8)
Offline Mike71
  • 1449
« Reply #8 on: April 14, 2004, 12:28:27 PM »
while making them all drool with the BOV...=)
Offline zooky
  • 135
« Reply #9 on: April 14, 2004, 12:40:01 PM »
stu
the only stock Samurai mechanical parts left on my Sami are the flanges on my Kicker3, and those are not even the flanges that came with the Sami ;D
EDIT: I guess they are not stock either, I had to modify them for the Toyota driveshafts
« Last Edit: April 14, 2004, 12:41:57 PM by zooky »
Offline 1bigtracker
  • 3409
« Reply #10 on: April 14, 2004, 01:46:36 PM »
well i don't hate them but its just frowned apon.  for example,  I LOVE jakes sammy.  it just takes all the fun out of running a zook.
stu
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #11 on: April 14, 2004, 02:04:26 PM »
stu
In a different thread werent you the one who said "Id just swap in a nine inch rear axle"?  ::) Somebody needs to make up their mind!  :P
Mike
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #12 on: April 14, 2004, 02:17:21 PM »
Mike
i think he meant "do as i say, not as i do"
« Reply #13 on: April 15, 2004, 03:49:42 AM »
;D
Then the turbo blew  >:(
But all is well, the engine is holding up fine
even under boosted conditions  :D
