4.3 swap
  • 14 Replies
  • 4200 Views
Offline ksbrauer
  • 21
4.3 swap
« on: May 29, 2012, 02:22:15 PM »
I have a 94 s10 blazer with a 4.3 and a samurai with the mounts in it so basicly I have an engine block and nothing else. What is the bare minimum I'd need to swap over from the blazer for it to run. Iv never did an engine swap before so its new to me but I am trying it anyway haha
Offline SineCredulitas
  • 73
Re: 4.3 swap
« Reply #1 on: May 29, 2012, 02:52:22 PM »
Not an easy job, iniazy has a Nissan vortec? build thread on another forum.  But it came from a sedan- on ZK
Would give you an idea of what you may have to do. There's got to be build threads in here, search them?
88.5 TT, dd, 1.6 16v, 5sp, a/c, SPUA, 30" MTR's
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #2 on: May 29, 2012, 06:22:06 PM »
Yeah mines the first year of the vortec and I have the whole blazer together right now still runs and all. Samurai actually has a vortec long block sitting in it now its locked up so that's why I bought the blazer and I figured I could use most parts off of it already to make it run. And I havnt searched many build threads yet havnt had a lot of time yet but ill have to keep looking
Offline Perryd
  • 202
Re: 4.3 swap
« Reply #3 on: May 29, 2012, 07:04:19 PM »
if it all possible, but it may be too late, the TBI 4.3s are much simpler and wayy easier to swap into things. I know the vortec engines can be a wiring nightmare.
1998 Tracker 2 door soft top, 3spd auto, 4x4, 215/57R15 BFG A/T, bone stock.
Re: 4.3 swap
« Reply #4 on: May 29, 2012, 07:10:33 PM »
If your samurai already has vortec mounts in it, that is a good start.  It is going to be a squeeze to putting it together, and VERY time consuming.  You need to know what makes the vortec run, electronics, fuel system, transmission/transfer case, etc.  You will probably need to do some welding and fab a lot of parts.  In able to make this work, you really need to be determined to make it work.  It is not cheap, but having a running parts rig will be a good asset.  It is not a plug & play (but you can probably find a P&P wiring harness).
This will make your Samuai very front heavy, not the nimble little light weight go anywhere rig it started out as.  And you will always be working on it.  Have fun.  Take lots of photos, post up questions and how it is going.  Any one who has done a swap understands when it just seems to have stopped, but you can get through that.
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #5 on: May 29, 2012, 07:18:03 PM »
I can probably use the vortec but just swap a Tbi on top of it? I'm sure I can find the parts easy enough or find an older s10 or blazer with this set up
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #6 on: May 29, 2012, 07:30:47 PM »
I actually have a manifold and carb I could use would just need to get carb rebuilt
Offline zuki1018
  • 397
Re: 4.3 swap
« Reply #7 on: May 31, 2012, 11:11:23 AM »
Have not done this swap but did swap a sami to a megasquirt fuel injected 16v.  I can tell you for simplicity, go carb if possible. That will free some of your frustrations up for other stuff! You can probably part out some of the FI stuff and recoup the rebuild kit money if thats all you lack to covert it.
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #8 on: May 31, 2012, 08:24:41 PM »
Well I defiantly am gonna go with the carb set up and I have a quadrant carb and manifold. The carb is pretty bad might just find a nicer used one instead of trying to rebuild and the manifold is rusty any one have any tips from removing rust. Maybe a good liquid to soak it in
  • 73
Re: 4.3 swap
« Reply #9 on: May 31, 2012, 08:59:01 PM »
diluted vinegar
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #10 on: June 01, 2012, 11:38:39 AM »
So fill a bin like half water half vinager and itshould help eat the rust away?
Offline 86samurai829
  • 124
Re: 4.3 swap
« Reply #11 on: June 02, 2012, 12:13:24 AM »
been thinking of doing the same thing, 4.3 V6 with a dana44 front and dana60 rear. saw a few videos of the 4.3 conversion on youtube and they look and sound great. really want to do it this winter! keep us posted of the build would really love to see some more details on the whole thing.
as far as i can see it would be pretty simple. theres a site you can buy the transmission mounts and other parts you need. http://www.suzukiconversion.com/suzuki_kits.htm and with stock headers you have plenty of room for everything. i've searched youtube for some videos and this is a good one
Suzuki Chevy V6 Samurai
im thinking im going to do this swap this winter, but im going to put dana 60 with 37's under my samurai.
« Last Edit: June 02, 2012, 11:11:37 PM by 86samurai829 »
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #12 on: June 07, 2012, 07:43:44 PM »
I actually have everything mounted up it was that way when I bought it. But the motor was bad. But my main job is to hook all electronics and fuel system up basically
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #13 on: June 10, 2012, 08:17:55 PM »
The 4.3 and 350 engines use the same carb? I thought they did but I wanna make sure before I go out and spend the cash on a new carb.
Offline ksbrauer
  • 21
Re: 4.3 swap
« Reply #14 on: June 19, 2012, 09:13:09 PM »
Just got a new heights distributor and have new carb on the way now just need to pull the motor out of my little blazer for the swap anyone wanna help haha
