Technical Discussion - Performance / Modify
Bump stops on a lifted tracker
vw505
133
May 28, 2012, 04:13:13 AM »
What are you guys doing for longer bump stops on the front and rear of your trackers?
talonxracer
1284
34
Re: Bump stops on a lifted tracker
May 28, 2012, 05:26:19 AM »
I did nothing up front, and used aluminum spacers in the rear between the rubber stop and it's mount. I removed the stock rear bumps, bought a few inchs of aluminum rod cut two spacers to length then drilled and tapped it. Threaded a stud into the body mount, thread the spacer on to the stud and the stock bump stop into the spacer.
Here is a commercially available spacer and what I patterned my DIY ones from, cheaper than shipping from the UK !!! LOL
http://www.bits4vits.co.uk/store/vitara-/-x90/bump-stop-spacers/prod_35.html
