i want to weld the rear end, the rear end on this vitara is new to me, i had over 5-6 ford rangers before with 8.8 rear ends witch i know i remove the rear cover then i can weld it up, but this vitara is making me ask sum question, what holds the axle in place? the brake back plate or sumthing? i know they will need to come out so i can take the 3rd member out to do the welding job. probably gona put in new seals at the same time as i will be right there and is not looking like an easy task.
