I've got a 1.3 in a 87 samurai that I built with .030 pistons, new bearings and rings with a 1.6 head with a high speed cam from low range off road a webber carb and thorley header. The motor ran great but I started getting a chatter that sounded like a loose valve adjustment. I adjusted the valves to spec but still had the chatter it does it worst in neutral while reving it or when driving but not under a load. It gets quiet under a load but gets louder the longer you stretch a gear out, the more it revs the louder it gets. While reving in neutral it gets lound but when you back off it quits for a second then starts again as it is winding down. At first I thought it was coming from the head so I pulled the shaved 1.6 head off and put the unshaved 1.3 head back on ( to eliminate what might've been spark knock) and adjusted the valves and now it's worse. My friend listened to it and thinks it's a rod, my father thinks it's coming from the bell housing, possibly the new flywheel is loose. I was so pissed after putting the 1.3 head back on and it sounding louder quicker I stomped the gas to the floor and held it to the floor while tearing my back yard all to hell for a full minute. Not the smartest thing to do but I'm at the end of my rope, and if it was a rod it should've came through the hood as i was turning around 10 to 14 grand. I know this is alot but I was going to sell it because of an upcoming rotor cuff surgery so i won't get behind on anything but I'm not going to sell it to someone untill I'm satisfied it's running right. Any ideas or thoughts would be greatly appreciated.
