Front Axle half Shaft help
  • 2362 Views
Offline TX-Trak
« on: May 08, 2012, 07:51:22 AM »
2 part question here:
I recently installed a 2.5" spacer kit on my tracker, now the axle boots on both half shafts where they attach to the differential are ripped.  is the spacer kit causing the axles to be at too much of an angle, and do i need to install a diff drop kit to lower the diff and decrease tha axle angle?
While installing the kit, i just removed the axles from the diff to allow the a-arm to drop low enough to get the springs back in under the spacers.  now that my axle boots are ripped, i've been looking at the repair manuals, and they seem to indicate that i should have marked the axle to differential location and installed back to the mark.  I did't do that, is this the cause of my woes?  If so, how to i get the correct alighment when i install the next set of axels?
Thanks in advance
john
95 tracker manual 4x4
02 Dakota Quad Cab
Re: Front Axle half Shaft help
« Reply #1 on: May 08, 2012, 09:36:22 AM »
What size spacers did you install on the front springs?  Did you also install a strut drop at the same time?
Offline TX-Trak
« Reply #2 on: May 08, 2012, 10:27:45 AM »
Bought a 2.5" spacer kit that included the 4 spring spacers, strut spacers, & rear diff spacer.  all installed at the same time.
02 Dakota Quad Cab
« Reply #3 on: May 08, 2012, 02:35:59 PM »
Where the front spacers a full 2.5" tall or only 1.5"?  To tall and you can risk breaking CV joints.
As for the boots, did they have oil on them or where they pretty stiff?  They can tear easier as they get older and are kind of a pain to replace.
Offline TX-Trak
« Reply #4 on: May 08, 2012, 07:05:22 PM »
well, the front spacers were almost the same as the rear spacers, they were probably a 1/4" or so shorter than the rear spacers. so probably 2.25" spacer in the front.  the boots werent bad looking before, the outer boots looked a little more worn, but the inner boots looked fine to me.  I think ive decided to go ahead and order drop brackets to lower the fron differential.  now my concern is with getting th new axles on correctly.  to your knowledge, does the rotation of the axel in relation to the differential matter, or can i just slap them on?
02 Dakota Quad Cab
« Reply #5 on: May 08, 2012, 08:36:46 PM »
Oreintation of the CV shaft to the inner axle shaft isn't that big of a deal.  Just put it on wherever it lines up.
Offline talonxracer
  • 1284
« Reply #6 on: May 09, 2012, 06:10:49 AM »
It shouldnt matter much at all in regards to the front axle phasing, CV's are far less susceptable to imbalance due to their inherently balanced tripod design and being hub centric.
Sounds like the OLD degraded stock boots simply couldnt take the additional flexing from moving the knuckle downwards in relation to the diff. You may be fine with just replacing the boots, but adding the diff drop will greatly extend the life of the CV's themselves as well as the boots.
« Last Edit: May 09, 2012, 06:15:36 AM by talonxracer »
Offline TX-Trak
« Reply #7 on: May 09, 2012, 07:45:55 AM »
I think i'll go ahead and get the drop kit and install befor i put on the new half shafts.
Thanks all for your help
02 Dakota Quad Cab
