Hagen Mod
  • 2995 Views
Hagen Mod
« on: May 03, 2012, 09:08:45 AM »
Hey,
I am just finishing up my Hagen mod and I have a suspicion that I made the "Stubby" shaft too long. I haven't cycled the suspension but assembling the strut with the CV seemed to be putting stress on strut / differential.
Any ideas if this binding will ruin the diff or strut ?
Damn.. may need a new stubby.
Re: Hagen Mod
« Reply #1 on: May 03, 2012, 02:22:20 PM »
Too long will cause something to break eventually, probably sooner than later. If it's just a bit too long, you could always shave a tiny bit off the end, that way you won't have to make a complete new one.
I understand how a too long shaft would put pressure on/in the diff but how is it affecting the strut?
Offline talonxracer
  • 1284
Re: Hagen Mod
« Reply #2 on: May 03, 2012, 03:53:51 PM »
Any bind will break stuff. Sounds like your CV's are bottoming out now and not allowing full suspension movement. Any play on the cv shaft end to end or is it tight as in bottoming out.
Re: Hagen Mod
« Reply #3 on: May 04, 2012, 09:04:09 PM »
What is the length of the stubby?
Re: Hagen Mod
« Reply #4 on: May 07, 2012, 02:12:59 PM »
Are you running the Calmini arms? the Calmini arm moves the front wheel forward and in doing so moves the CV a further inch out. If you have the stock arms you may need a thinner stubby.
Re: Hagen Mod
« Reply #5 on: May 09, 2012, 08:13:28 AM »
This is the first I have heard about the Calmini arms moving the position of the wheel. I thought they were just "Fancy" looking stock arms w/ a modified spring perch.
I just widened with the stock arms. My stubby was about 1,25" long and causing the CV shaft to bind, I had to cut it down to 3/4" and it is working fine now. Thanks for the help everyone.
Not sure, I would think that when the CV was bottoming out the pressure it exerted was half on the strut (connected to the knuckle as you know) and half on the diff.
To be honest I was trying to avoid having to countersink the bolt holes in the stubby to clear the diff mount bolts. I will put up some pictures in my build thread shortly.
Offline tipover
  • 422
Re: Hagen Mod
« Reply #6 on: May 09, 2012, 04:27:29 PM »
Yea I got Calmini arms and stock arms on the floor and the calmini moves the ball joint out about .5 " and forward .5".  Basically the same thing as Hagens mod.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Re: Hagen Mod
« Reply #7 on: May 10, 2012, 04:18:11 PM »
The Hagen mods actually move the center point of the front axle forward almost 1.5"  Either that or I did mine really wrong! :laugh: It does move them out .5" though.
Re: Hagen Mod
« Reply #8 on: May 11, 2012, 02:23:09 PM »
Mike Hagen was running the Calmini arms when he did the mod.
