I just got back my ECM for a cap repair and put everything back together, but I still get no fire. When I do the check engine flash diagnostic fuse, I get 4-1, ignition signal.
Originally I replaced by distributor and ECM, as someone stole them from the vehicle. I replaced both parts, and asked for the color codes for the wiring because the thief cut off the distributor harness (blue/red->red, black/green->brown, black/blue->black/white). That is all re-connected.
What causes that error code? No feedback from the hall-effect in the distributor due to no spark? It is spinning. I get no spark from the coil, but I have another one of those also and it tests OK with a meter. The igniter and coil were left, they were working fine.
The guy that rebuilt my ECM said he didn't have a Sammy to test to make sure it worked 100%. Is there someone I can send it to verify that isn't the problem?
