newbie need some help
  • 1174 Views
« on: April 23, 2012, 07:07:23 PM »
My 95 sidekick is a dd too but wheel on the weekends
So I was wondering what would be the cheapest way to lock my front end to make it
Pull both wheels, but still be fine with the daily driving and I don't want to go crazy with it something simple
Thanks for the input
95 kick 2dr 2.5 lift springs and 31 kumho m/t
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: newbie need some help
« Reply #1 on: April 24, 2012, 02:24:48 PM »
The problem with locking the front axle (or even installing a Lockrite or similer device) is the fact that the aluminum differential and axle housing may not last very long under the stress of a locker.
Something to think about...
Ack
« Reply #2 on: April 25, 2012, 09:17:37 AM »
As for the easiest, Low Range has a locker that will bolt into the stock aluminum carrier:
http://www.lowrangeoffroad.com/index.php/suzuki/sidekick-tracker-x90/axles/front-lockright-locker-system.html
We have also swapped in steel carriers either from Grand Vitara's or modified Suzuki Samurai diffs.  Then you can use a standard lock-right or ARB.  For a dd I recommend spending the extra money on an ARB, it's worth it once you use one.
