weber carb swap check engine light
  • 1777 Views
« on: April 21, 2012, 12:40:58 PM »
so i just got my weber carb on and i was wondering if my check engine is going to stay on because i am no longer running the electric carb?
Re: weber carb swap check engine light
« Reply #1 on: April 21, 2012, 12:49:44 PM »
also if you have done this swap and can tell me what i need to do to fix this that would be grate
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: April 21, 2012, 06:56:10 PM »
The easiest way to fix that problem is to remove the ECM.   It's been so long since I installed my Weber that I can't recall if the Check Engine light came on afterwards.
I hope that this helps!
Ack
Offline rascott
  • 669
  • 15
« Reply #3 on: April 21, 2012, 07:03:36 PM »
yes
the check engine light will stay on.
removing the ecm will kill it.
i have done this.
« Reply #4 on: April 22, 2012, 01:45:40 AM »
what about passing smog here in Oregon they check to make sure that the check engine light works I was thing about putting a diode in the alternator charging line and running a solenoid to the check engine light but i cant find a diode in the right size
