Technical Discussion - Beginner / Repair
Transfer Case Swap
Transfer Case Swap
cwright
7
Transfer Case Swap
April 02, 2012, 07:41:39 PM »
Will a 97 sidekick transfer case work in a 88 Sammi? Thinking positively......If so what do I need to swap to make it work?
SIDEKICK65
176
Re: Transfer Case Swap
April 04, 2012, 01:31:50 AM »
No
Drone637
8121
116
Evil Cow
April 10, 2012, 11:42:15 AM »
What Sidekick65 said.
The sidekick transfer case doesn't have a high-range reduction like the Sammy ones does, if you want to run dual T-Cases you need a Kicker3 style setup. Then use the Tracker 5-speed as well as a 1.6l. It's a bit of work but pretty cool once you get it setup.
fleX90
11
Reply #3 on:
April 11, 2012, 05:05:33 PM »
Ive heard that OTT are no longer producing anything. correct me if im wrong
