Hanma 4x10w CREE spot module
  • 1727 Views
Offline talonxracer
  • 1284
« on: March 27, 2012, 10:03:52 AM »
Well the DHL guy delivered the rest of my lighting today. To augment the 120W flood light bar from Hanma, I decided their HML1640 would be perfect.
These aluminum die cast modules have four 10w CREE LED's and is approx 4.25"x4.25" and have two mounting options, either the bracket at the bottom, or a pair of flat plates attached to the rear of the module.
These lights are advertised as 3200lm at 6000K and available in 25 and 40 degree lights. I got the 25 degree spot lamps and plan to mount them on the roof(Rally hardtop) on either end of the flood bar.
in the box
front
the rear
side
and with both types of mounting installed
I will make up a set of pig tails with alligator clips to take some night shots later this evening.
Re: Hanma 4x10w CREE spot module
« Reply #1 on: March 27, 2012, 03:26:14 PM »
I like the alternative mounting tabs for a flat mount.  While not adjustable it makes it easy to put on a flush surface.
« Reply #2 on: March 27, 2012, 04:30:44 PM »
Any lights , or anything else for that matter, mounted to my roof would last approximately 1 ride. The trees must be pretty tall out there.
Offline 87Suzi
  • 156
  • Love this little thing!
« Reply #3 on: April 01, 2012, 07:18:13 AM »
When do we get to see these installed and in action?? ;D
Offline talonxracer
  • 1284
« Reply #4 on: May 10, 2012, 06:14:47 AM »
Well I rearranged the spot modules from being slung under the pushbar to above the pushbar. This places them just about even level with the stock headlights. And it does put down a better beam pattern than when mounted down low.
Here is the spots only when slung under the pushbar, they need a little aiming in this pic, but still reach far further than the Silverstars.
silverstars
this is with everything powered up,
« Last Edit: May 10, 2012, 06:20:52 AM by talonxracer »
