Members Rides Info thread (PICTURE THREAD)
  • 866 Replies
  • 467165 Views
0 Members and 15 Guests are viewing this topic.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Members Rides Info thread
« Reply #75 on: August 19, 2005, 06:58:16 PM »
Hold it!!!!!!!!!
     Is that a "Cast Iron" exhaust manifold? All the ones I've seen up here in the Great White North have a tube type exhaust manifold that looks alot like a Calmini header!
Zag
That's what us USAans got when we went to the dealership to pick up a new one...
I've heard tell that broken cast iron manifolds were common on the early 1.6 engines.  Around 1994, they changed from what is pictured to an even beefier cast iron unit, which is what I bought on eBay.  Me and the muffler shop were able to "adapt" it to the rest of the exhaust system with a matching downpipe (Thanks Hawk's!), a new cat and a length of pipe.
The older manifold (pictured above) had a two-pipe downpipe that reduced to a single pipe where it attached to the cat.
Ack
Offline Autobot
  • 189
  • Danger Can Happen!
« Reply #76 on: August 19, 2005, 07:16:07 PM »
My baby  ;D :
Year: 2000
Type: 2dr Tracker Convertible
Engine: 1.6l 16v
Transmission: 5spd.
Gears: stock
Everything else: Stock, stock, stock, stock...
Future plans: Small lift, some bigger tires, rocker gaurd/nerf bars , grill guard. Maybe someday a 2.0 engine swap.  :)
Got Tracker?
2000 2dr. convertible, stock.
Offline Dihnekis
  • 398
« Reply #77 on: August 20, 2005, 09:21:12 PM »
Year: 1994
Type: 2WD Geo Tracker convertible
Engine: 1.6l 8v
Transmission: 5speed
Transfer Case Gears: real men have one power wheel
Diff Gears: no idea
Lockers: none
Tires: 195/75/15 Tiger Paw
Wheel/Backspacing: 15" stock aluminum 5 slots standard backspacing
Body Lift: none yet
Front Suspension Lift: none yet
Rear Suspension Lift: none yet
Steering:worse than stock due to bent tie rod, terrible alignment, now is a bitch to turn to the left and has no power steering
Front Differential Housing: imaginary
A-Arms: stock
CVs: Stock
Hubs: invisible
Rear Axle: Stock
Recovery: stock tow hooks
Custom: lots of sand on the interior, new pushed in front bumper due to friend bagging a pair of trees when I let him drive because I'm stupid, dented front right fender due to sister nailing an Altima because she couldn't find the brake pedal apparently, completely cracked exhaust pipe and massive oil leak
Communications: yelling (CB install is on the menu)
Tunes : Pioneer CD player hooked to 20gb rio karma with 5k songs on it, Infinity Reference Series 4" up front and 6 1/2" in the back, best part of my trackick.
Coming very soon: Spool or locker for the rear, Calmini performance exhaust, K&N air filter, Calmini 3" body lift, 31" Dunlop Mud Rovers, and maybe at some point in the future a transfer case and front axle
White95 I stole your template, thanks :)
1988 Suzuki Samurai
Offline Shreg
  • 30
« Reply #78 on: August 24, 2005, 05:02:49 PM »
OK shreg, that's some sik shiat ...
gotta ask why not full width on the d60's and 44's  ;D  ;D  ;D
The altezza tail lights are a nice touch (fawkin poser :) )
Yer spot on, full width on a Zuk is the shizat....all D60 on this truck, no spindly 44 junk ;D
I should have clairified, I said other "Suff", I should have said other "Bling"...  Fawkin foot pedles glow too.....  Its the shiznizzle.
Were gunna be "Posin" with this rig at DTC this year, your welcome to join us on a quick Posin run through Hal Johns..... ;D
« Last Edit: August 24, 2005, 06:04:53 PM by Shreg »
Offline sj416 nz
  • 38
« Reply #79 on: September 12, 2005, 12:37:57 AM »
1986 sj413
Motor
1.6 16V
Airflow snorkel.
Free flow exhaust and 2.1/4â€? exhaust system.
Driveline
calmini 5.14 Transfer case.
RRO mega grip arms and poly mounts.
Center force dual friction clutch.
3.90 R&P.
Suspension
Calmini 3.5�lift kit with reset std springs
Tires/Wheels
31x9.5-16â€? simex jungle trekkers.
16â€? Sidekick rims.
86 sj413
1.6 16 valve
5.14 t-case
32" simexs
airtec snorkel RRO coil kit toyota running gear 4.88
Offline LWB Samurai Joe
  • Diesel samurai's rule!
« Reply #80 on: September 20, 2005, 09:37:52 AM »
1987 LWB Samurai.
1987 Suzuki long wheelbase samurai
1984 toyota 2.4 liter 2LT turbo diesel motor
1984 toyota 5 speed tranny, t-case with Marlin 4.70 low range gears
1983 toyota front axle, 5.29 gears, ARB locker and high pinion 3rd member, Longfields, vented disks with four piston calipers
1983 toyota rear axle, 5.29 gears, ARB locker, V6 3rd member, Front Range full floater kit with 4140 axles, disk brakes with four piston calipers
FJ80 master cylinder and power booster with proportion valve
Toyota IFS power steering
Sky manufacturing high steering
Marlin 4.70-1 transfer case (98 to 1) with dual sticks
Custom four link rear three link front coil suspension
38.5 x 14.5 x 15 SX swampers on Marsh racing 36 bead locked wheels
FULL herculined tub and partial exterior
Autometer gauges in the 5 vent holes
Extrememaire compressor with 5 gallons of onboard air
custom rear bumper, 2x5 gallon gas carrier, rear Ramsey 8000lb winch
custom rocker skids
Trail Tough front bumper with Ramsey 9500 Patriot winch and IPF lights
6 point DaveSport full cage, and exo portions
Corbeau sport seats
Trail Tough fold down windshield
cut door hinges for door removal
Custom soft top
15.5 gallon gas tank
TrailTough fender flares
Centerforce dual friction clutch
Amsoil bypass filter
Flex-a-lite dual electric fans
200 amp battery isolator
One optima red top
One optima yellow top
2001 VW TDI Bora
1987 Turbo diesel LWB Samurai
1987 Toyota HZJ-60
Offline andyt87
  • 146
  • I LPVE ZUKI WORLD!
« Reply #81 on: September 20, 2005, 12:27:14 PM »
Damn that LWB is fine!!! ;D good job!
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
« Reply #82 on: September 20, 2005, 05:38:15 PM »
Thanks.  Here are a couple naked shots for you.
Tom
« Last Edit: September 20, 2005, 05:41:22 PM by LWB Samurai Joe »
2001 VW TDI Bora
1987 Toyota HZJ-60
Offline 1bigtracker
  • 3409
« Reply #83 on: September 21, 2005, 06:05:37 PM »
Tom
ummm topless ;D   one of the niceest i've ever seen.
Stu
Offline andyt87
  • 146
« Reply #84 on: September 22, 2005, 10:15:49 AM »
 :o
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline andyt87
  • 146
« Reply #85 on: September 22, 2005, 10:17:47 AM »
i just noticed something, i could be my eyes... but is the license plate someting something "LWB"???  cos that would be damn cool!!!
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline blacktrack99
  • 254
« Reply #86 on: September 22, 2005, 05:30:10 PM »
New guy's ride.
'99 Tracker
RRO suspension lift
235's
Rally Tops removable hard top
More to come.  I'll post as it progresses.  Sorry about the low res shots..
  • 6554
  • 64
« Reply #87 on: September 23, 2005, 10:21:17 AM »
I think it's [dsl lwb] as in diesel long wheel base...
Offline zaggy
  • 1134
« Reply #88 on: September 26, 2005, 11:01:04 AM »
So I figured it was time to post my favorite Suzuki here.....
- 113-114hp 1.6/8v extremely modified (see pics of Zaggy's engines on the Suzuki forum)
- Empty weight 860lbs
- Max weight 1500lbs
- Cruise (from inital flight on weekend) 122mph
More info when it comes availabile from testing.
This picture is from just before first flight.
Zag
« Last Edit: September 26, 2005, 11:04:18 AM by zaggy »
Offline 96SidekickSport
  • Suzuki = GODzuki
« Reply #89 on: September 26, 2005, 08:05:29 PM »
Well heres my zuki...my first car and i LOVE IT TO DEATH...after finding you guys im glad its a suzuki with all the possibilities  ;D lol some one please help a 17 yr old kid with a knowledge of cars from growing up in an automotive garage buisness and keeping a short budget lol
if any of yall got aim - V Needs Speed feel free to IM
