Members Rides Info thread (PICTURE THREAD)
  • 866 Replies
  • 467417 Views
0 Members and 37 Guests are viewing this topic.
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
Re: Members Rides Info thread (PICTURE THREAD)
« Reply #495 on: September 03, 2008, 04:52:40 PM »
ok here it is finally the cold air intake
Offline Carnage
  • 2453
« Reply #496 on: September 05, 2008, 10:07:27 AM »
cool
but dude, thats a regular aftermarket intake
a CAI doesnt take in hot engine air because it (typically) runs down through the fender
(or blocks off engine heat [somehow])
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #497 on: September 05, 2008, 10:56:46 AM »
cool
Yep.  That's low-restriction (although also probably low-filtering...see http://www.bobistheoilguy.com/airfilter/airtest1.htm...), which may help, but not cold-air.  So far, I've stuck with the stock airbox; it's of a higher-restriction, but it also draws colder air from the fender.  My guess is it's probably close to a draw, one way or the other.  One of these days I'm going to implement a real solution; cowl-induction would be....cool....
XL-7 front coils
1.5" rear coil spacers
Offline Carnage
  • 2453
« Reply #498 on: September 05, 2008, 12:33:11 PM »
cool
aftermarket intakes look cool but i think im over it
K&N or Trueflow drop in filters will do it now
and i know it means a lot in the mainland
but i always laugh when i see "colder air" from the fender
as its always warm where i live
Offline kubik1981
  • 232
« Reply #499 on: September 05, 2008, 06:50:41 PM »
i know its not much but it is a lot better then what was in there when i bought my track. there was nothing the guy had nothing there just ran off the plenumm without a filter
Offline Carnage
  • 2453
« Reply #500 on: September 05, 2008, 08:08:57 PM »
lol
shouldve got a pic of that
Offline kubik1981
  • 232
« Reply #501 on: September 05, 2008, 08:18:21 PM »
i should have recorded the sound the engine made when i got it.  When i got it the #4 rod bearing was toast so i rebuilt the whole engine and head ground up it set outside for about a yeah with just a bikini top on so i had to clean out a inch of leaves out of the backseat.  also where the clutch cable came through the firewall had rusted out so the guy put a c-clamp on there to hold it.  the little compartment on the top of the dash was full of ciggerett butts.  it was nasty but i only paid 200 for the truck with 95000 miles on it.
Offline heiney.5
  • 175
  • 9
first post....Geo Project
« Reply #502 on: September 10, 2008, 12:12:29 PM »
Well I have been trolling this forum for awhile, so I'll finally post some of my project pics.
My ride:
'94 Geo Tracker
2" body
1.5" spacers
Moderate Trimming
31x10.50r15 Trxus MT
Rear spool
Calmini intake
Relocated fuel cell and optima
bobbed frame 5"
Few pics:
---------Before
-------I got carried away cutting out rust
-----Bobbed frame
------Fuel delivery new set up, also notice nice black frame(right)...courtesy of Chassis saver
-----New fuel cell and battery location
--------out for it's first run
It is not nearly done, but it's definitely started. ;)
Offline Praise Him
  • 256
« Reply #503 on: September 12, 2008, 08:57:22 PM »
I am unable to update my post in this thread so I figured I'll just post again with the updates...
Year: 1991
Type: Tracker
Engine: Stock 1.6L 8V
Transmission:  5 speed manual
Transfer Case Gears: Twin T-case (kicker 2)
Diff Gears:  5.38 Locker in the rear
Tires: 32x9.50 tsl Super Swampers
Wheel/Backspacing:  15x7 with 2.5" B.S with beadlocks
Body Lift:  3"calmini
Suspension 3"calmini
Other:
on board air
Doug Thorley header with 2 1/4" exhaust
front and rear winch (receiver style)
custom front and rear bumpers
K&N air filter
Optima yellow top batterie
Nice HardTop :)
sammy/toy axles/locked/geared/cased/36's
Offline Shredder
  • 389
    • Me & My Rig
« Reply #504 on: September 14, 2008, 10:28:53 AM »
Here is my latest project. A '91 Tracker with Toyota axle swap on Jeep YJ springs using an experimental bolt-on swap kit from Boondox. I went with spring under because it was I only have 31" tires for it right now. It has about 16" under the frame rails. http://www.zukiworld.com/forum/index.php?topic=22682.0
Offline hawaiizuki13
  • 51
« Reply #505 on: September 25, 2008, 10:38:00 AM »
othing much but spoa with 2 inch shackles and 3 inch spring with 31 swampers gears are stock going to upgrade them and lift it higher
« Last Edit: September 25, 2008, 10:44:51 AM by hawaiizuki13 »
LOVE TAKING A ZUK RIDE WITH MY FAMILY
Offline jeff1997
  • 1228
  • 27
« Reply #506 on: September 25, 2008, 12:13:18 PM »
VERY nice. I love the white with black rims.
3" Masterkit1 body lift
Custom strut spacers
  • 51
« Reply #507 on: September 25, 2008, 12:27:37 PM »
thanks jeff yeah im gonna go highger and wider on the wheels maybe 16 by 16 with 33's and maybe 4 inches higher ;) stay tuned lol
Offline Carnage
  • 2453
« Reply #508 on: September 25, 2008, 10:06:53 PM »
nice ride hawaiizuki
where you stay
hilo?
  • 51
« Reply #509 on: September 25, 2008, 11:15:05 PM »
yeah i live big island keaau tho where you from bro?
