Here is my rig once again in a slightly different, slightly more capable format.
1997 Sidekick 4 door, 5 speed, 16 valve
Digger's 1.5" coil spacer lift, Crown Vic rear shocks, flipped front strut mounts
Sky Manufacturing 2" body lift...really wish I could have made it myself but in the end it didn't work out.
31x10.50 West Lake CR857 M/S tires on 15x7 Jeep CJ rims with 3.75" backspacing
Detroit Locker rear
2" catback exhaust with Cherry Bomb glasspack
Cut out the doorsills and welded in 2x4 1/8" wall rectangular tubing. Looks clean, work excellent as sliders and hi-lift jack points
Bright green custom skid plates
Cobra CB radio, needs a new antenna though
Monroe brakes
Powermax wires, NGK Platinum plugs, Bosch 02 sensor
On the to do list:
Install the 4.24:1 t-case gears I have in my room
Rebuild tranny
Replace clutch (running the hardcore trails with 31's and stock t-case gears= no no)
Build a grille for the lower rad
Get a matching spare wheel
