Members Rides Info thread (PICTURE THREAD)
  • 866 Replies
  • 466804 Views
0 Members and 14 Guests are viewing this topic.
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
Re: Members Rides Info thread
« Reply #30 on: May 01, 2005, 09:26:05 AM »
1995 vitara lwb
3" calmini suspension+1" rocky road spacers.
1.5" rocky road body lift.
235/85x16 mud tyres on gv rims.
lock rite in the rear.
5000lb winch on the front
safari snorkel
cb radio.
rear door ladder
stock engine and drive train.
95xl7
« Reply #31 on: May 01, 2005, 10:06:30 AM »
1995 Geo Tracker 2 door
engine: Stock Suzuki 2.7ltr
transmission: 4 speed auto w/od
differentials F&R: stock 5:13 ratio
body: 2" RRO body lift
suspension: stock w/ 1.25 spacers in front only.
wheels: centerline HT33's 15x7
Tires: 255/70/15's Yokohamas
interior:stock except aftermarket wheel
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« Reply #32 on: May 02, 2005, 01:33:46 AM »
Year: 1996
Type: Geo Tracker
Engine: Stock 1.6L
Transmission:  5 speed manual
Tires: 215 75R15's Supersports
Suspension Lift: Custom GV Spring Variation /w 1" Rear Spring Spacers for 2inch all around at the frame
Recovery: Towstrap, gloves, jack and sister
Custom: Not much now that I think of it, I should go to the garage... I think I ziptied something together yesterday, does that count? Oh, I made a lightbar, pics to follow..
Communications: Horn and Finger
Tunes: Pioneer Headunit, 4's in the front, 6x9 two ways in the rear and 600w amp in a false trunk floor (we have trunks?) powering a 10inch subwoofer
Navigation: Garmin Etrex Venture GPS
Tires don't rub, and I have no fear of highway speeds for extended periods of time... yeah I'm trying here.. he he
« Last Edit: May 02, 2005, 01:36:17 AM by CBTracker »
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
« Reply #33 on: May 02, 2005, 02:07:00 AM »
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline b1pig
  • 61
    • Jeep
« Reply #34 on: May 02, 2005, 09:14:27 AM »
This is the pic of it right after I got it... no lift.
I'll try to take  a current pic tomorrow and post it.... tho it ain't much different...
Year: 1990
Type: Tracker
Engine: Stock 1.6l 8 valve
Transmission: Stock auto
T-case: Stock
Diff Gears: stock..  4.somethin
Tires: 235-70-15 BFG street tires. ->not my fault. were on it when I got it. :)
Wheel/Backspacing: 15x8 American Racing Chrome with 3.75" backspacing
Body Lift: pending
Suspension Lift: ProComp 2.5" suspension lift... or peices of it anyway... (super stiff)
Front axle: Stock
Rear Axle: Stock
Recovery: Pair of boots, 1 good back
Tunes: JVC CD, wall-world 4" Spkrs in front, Jensen 6x9s in the back
b1pig
'90 Tracker, '07 JK Rubi
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #35 on: May 02, 2005, 11:02:25 AM »
1985.5 LWB suzuki samuria
Rebuilt 1.3L
2"lift
3.90 gears, welded rear
32" 7"wide skinny biasply tires
Custom roll cage
RCI racing buckets
Custom exaust with a red hot glasspack
Cb radio
Prety stock for now, doing a SOA soon and adding a few things here and there.
Offline xamtex
  • 72
« Reply #36 on: May 02, 2005, 11:49:31 AM »
Suzuki Model/Year:91 LWB sammi
Engine:1.3 with janspeed exhaust system
Tranny:stock
Transfer Case(s):4.16 with 2wd low
Front Axle & Gear:3.9gears with lockright,birf rings(almost)diff armour.axle truss
Rear Axle & Gear:3.9 with lockright
Front Springs:custom RUF with long shocks
Rear Springs:custom rears with terraflex hypershackles
Tires & Rims215 x 15 diamond back race tyres on 7 inch rims
body mods:pickup cab and flatbed rear
Frame Mods:bobtailed rear.t/case skid plate. full exo cage.
Other Mods:power steering.custom front and rear winch bumpers.WARN 9.5TI on the front.GEW 9000 on the rear.snorkel
Wheelbase:95 inch
« Last Edit: May 02, 2005, 11:51:34 AM by xamtex »
god must love crazy people,he made so many of them!!!
Offline szabotage
  • 114
  • snaggletooth
« Reply #37 on: May 02, 2005, 02:58:30 PM »
my daily driver
85 samurai
-SPOA
-breeze X over steering
-front panhard bar
-1.6 8v efi w/ DT header
-235 bfg all terrains
88.5 tranny
3.90's
my trail truck
85 lwb
-SPOA
-dual shackles
-Cj / Ruf
-X over steering
-rear traction bar
-hybrid front and rear kick axles
-5.13's lincoln rear
-1.6 8v efi w/DT header
-90amp GM alt
-5pd sidekick tranny
-dual kick/sammi t'cases
-33" thornbirds
-10 pt cage
-100" wheelbase
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #38 on: May 02, 2005, 04:57:52 PM »
Year: 97
Type: sidekick
Engine: 1.6 v16
Transmission: auto
Transfer Case Gears: I wish
Diff Gears:  I wish
Lockers: rear
Tires: bfg at
Wheel/Backspacing: ?
Body Lift: 3
Front Suspension Lift: 2 in bds and 1in jeep spacer
Rear Suspension Lift: 2in bds
Extras: home make safari snorkel
Do your Tires Rub: no
Roll Cage:  I wish
Winch: 8000
Etc: home make half doors
« Last Edit: May 04, 2005, 12:29:38 PM by safarikick »
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #39 on: May 03, 2005, 03:11:00 AM »
1988 Suzuki Samurai, aka "The Popsicle"
Motor
1.6 8v with efi
K&N Filter
GM alternator
2� exhaust system
Ford HP fuel Pump
Redtop Optima
Driveline
RRO 6:1 Transfer case with mega grip arms and poly mounts
Trail Tough 1.8:1 Rock Block
OEM Aisin Clutch
Toyota Minitruck axles 4.10 R&P
Front and Rear Lockrite Lockers
RRO KAD Front Driveshaft with Rat Adapter
Rebuilt Toy IFS front driveshaft with Rat Adapter in rear
Steering
Sky-Mfg Hi-Steer
PSC Hydro assist (6" Ram, TC pump, and Bling Res)
Spidertrax ps pump bracket and pulley
Toy IFS gear box
Suspension
RRO Coil Kit
QA1 14 inch 165lb Springs in the front
QA1 14 inch 175lb Springs in the rear
Doetsch Tech 8000 series Shocks
22 inch brake lines
Tires/Wheels
35x13.50x15 BFG Krawlers
Allied 32 bolt Rockathon Beadlocks
2 inch aluminum wheel spacers
Armor
Shrockworks front winch bumper
RRO Rear Crawler bumper
Shrockworks custom Sliders
Shrockworks Gas Tank Skid
Rock 4x Fabrications custom Full Cage
Rock 4x Fabrications T-Case Bucket
Interior
2 screaming kids
ABS door panels
Power Tank
Jegs Poly seats with cool orange covers
Krawgard spray in liner
mini buckets in back for the screaming munchkins
4 pt harnesses for everyone
Cheap CB
Garmin Rino GPS/Radio
Exterior
Popsicle Orange Paint
Fold Down Windshield kit
Tube Doors by Zukizzy's Garage
Rock Lights
dents and scratches
various stickers
Recovery gear
Warn XD 9000 winch, fairlead roller
Recovery gear by Masterpull (snatch strap, shackles, tree saver, chain, snatch block)
Hi-Lift jack
Fire extinguisher
First Aid kit
« Last Edit: July 06, 2005, 03:01:17 PM by nc_zuk »
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
« Reply #40 on: May 04, 2005, 12:15:32 AM »
Well, there is no pic because it's scattered all over the property, but mine is a little different.  8)
It's a std Sammy drive train & chassis that I'm fitting a flat fender jeep CJ3a, fiberglass body to.  Plan to paint it up as a WWII army jeep w/graphics.  Pics when it's a little further along.  Currently rebuilding all the drivetrain components and moving the engine mounts back |removethispart|@ 6" and shortening driveshaft etc.  This should weigh well under 1800#  2 people can easily pick up the body & walk around with it.
GS
Offline kotsh
  • 23
« Reply #41 on: May 06, 2005, 04:59:27 AM »
1990 soft-top Sidekick from Israel . manual 8v
Started its life in States and was brought to Israel 2 years ago
Mostly stock but has a few mods
Tjm lift springs and Monroe shocks
Projeep aluminium skidplates
Warn premium manual locking hubs
Hella foglights
Free flow exhaust
sheel-mann drivers seat
wheelskins leather wheel & momo leather shift knob
no other serious mods mostly because of the lack of funds and also because of very strict (and stuped)restrictions in Israel.
But i  like wheeling it as it is ;D
Have fun with your Zukis everybody!!!!
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #42 on: May 09, 2005, 04:19:24 AM »
Year: 1992
Type: Tracker
Engine: Stock 1.6L 8V with 128,000km
Transmission: 3 speed auto
Tires: 215/75/15
Wheel/Backspacing:  15x7 w/ 3.75 BS, Jeep CJ
Communications: Cellular Phone
Tunes: cd/am/fm, clarion 4" dash, 8" woofer in rear
Pretty plain, but I wheel it anyway!!
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #43 on: May 13, 2005, 07:31:03 AM »
Specs:
1988.5 Samurai JX
stock 1.3 with Pony Carb
centerforce dual friction clutch
4.10 T-Case
Rock Block
Sky Crossover steering
Spidertrax 1" wheels spacers
4.62 Diffs
loc-rite front, lincon locked rear
rear hybred axel
trac-bar
RUF with M/L, Front CJ's rear with custom Goofy leafs
33x13.5x15 Swamper LTB's on 15x10 bling-blings
Full cage, CB, CD player, 5-point harneses
« Last Edit: May 13, 2005, 07:33:17 AM by purevil71 »
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline kansascitytracker
  • 335
  • 92 Tracker
« Reply #44 on: May 15, 2005, 02:59:23 PM »
Click on links to view
file://localhost/Users/blvsstudent/Pictures/DSC00449.JPG
file://localhost/Users/blvsstudent/Pictures/DSC00447.JPG
file://localhost/Users/blvsstudent/Pictures/DSC00446.JPG
1992 Tracker.
Uniden CB
Pioneer CD/AM/FM/XM Satellite Radio
3" Clamini Body lift (collecting dust,begging to be installed)
Altezzas now
1.6 5-Speed, Factory AC that actually works
