1989 Vitara Soft top
1.6lt,  8 valve
Weber Carby
Extractors
2" exhaust system
5 speed manual
Standard Transfer
Rear Lock Right Locker
Standard 5.12 diff ratios
Standard Brakes
3" body lift
3" suspension lift
FRONT:
OME Front Struts
Flipped Mounts
2" coil spacer
REAR:
Longer shocks (25.5" extended, 12" compressed)
2" lifted coils (soft spring rate)
1" coil spacer
3" A-Arm spacer (not installed yet)
GoodYear Wrangler MT/Rs, 33"x12.5"x15"
15"x8" Ford F100 wheels (3" B/S)
INSIDE:
Sony CD/MP3 head unit
Sony 6" (2 way) in Doors
Sony 6"x9" (3 way) in the back
Checker plate (AKA diamond plate) interior
No carpet (hose out interior)
Canvas rear seat
Custom soft top
Front and rear tube bars (overkill engineering australia)
braced and fitted, with some bling checker plate
Rock sliders are in production
TO DO:
working on a 5" suspension lift
snorkel
3" fuel tank lift (
DONE)
winch (do i need one?)
Transfer reduction gears
roof mounted light bar
PLANS:
31" SIMEX Extreme Trekkers
EXTRAS:
Do your Tires Rub:  they do now
Hwy Driving RPM:  not sure yet, will find out soon
Spot Lights up front
Had to cut rear of front guards, and the firewall made friends with my BFH too.
1992 Sierra (was a Soft top)
1.3lt
Standard Carby
Snorkel
Extractors
2" exhaust system
5 speed manual
Standard Transfer
No Lockers (yet)
Standard diffs
Standard Brakes
2" body lift
2" suspension lift
Standard Leaves (removed leafs)
FRONT:
OME Front Shocks
4" extended shackles
REAR:
OME shocks
4" Extended Shackles
GoodYear Wrangler MT/Rs, 30"x9.5"x15" (front)
BFGoodrich M/T, 30"x9.5"x15" (rear)
soon to be 32" MT/Rs
INSIDE:
no rear seats (obviously)
Custom UTE conversion
hard top over cab
TO DO:
Lockers
EXTRAS:
Do your Tires Rub:  a bit
Hwy Driving RPM: we dont use 5th gear in the city, and top speed is about 90km/h.
Custom gun rack behind cab
PLANS:
SPOA conversion
RUF
shock hoops up front
welded front
lockright rear
32" swampers
