winch mount
  • 19 Replies
  • 2835 Views
Offline flanny
Re: winch mount
« Reply #15 on: March 23, 2012, 08:50:09 AM »
this is what i have to work with, as you can see the motor takes up alot of space.
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
FORD 5.0 HO MOTOR WITH TRANNY
Offline flanny
Re: winch mount
« Reply #16 on: March 23, 2012, 08:54:46 AM »
i ran a 5" c channel across the front and notched out for pulleys and radiator hose. this attaches in 6 places along the frame so its sturdy
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
Offline flanny
Re: winch mount
« Reply #17 on: March 23, 2012, 09:00:54 AM »
i ran 2" c channel 3/16" thick for my winch base and all support brackets. strong but lighter than a plate.
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
Offline flanny
Re: winch mount
« Reply #18 on: March 23, 2012, 09:10:44 AM »
Got most of it finished. still have to mount the fairland, add d rings, wire her up,once i test her our and make sure she holds ill be painting, diamond plate, and custom radiator shroud.
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: winch mount
« Reply #19 on: March 23, 2012, 11:52:19 AM »
Thanks T-Racer... I wasn't sure bout the pump. I know this is very do-able and once completed it would make more sense than having the radiator stuck out front asking to be damaged. It would make the Sammi look right too.
With a lil research on rear mounted radiator systems I think Flanny could get all of the rite answers and continue making his a Super Sammi....  ;)
