Built Nissan Patrol axles, perfect for a Suzuki or similar
  • 0 Replies
  • 1210 Views
Offline RMPO
« on: March 19, 2012, 06:12:48 PM »
Selling a set of built axles from a 1980s 160 series Patrol.
Front is a C200, number indicates ring gear size in mm. No drop out 3rd on this one. It is fully rebuilt, everything is new. Loaded with an ARB locker and 4.6 gears. Over sized CV joints and hubs, from a H233 Patrol front axle. The CV is also heat treated and has a ring welded on it. Hubs are also from an H233. High steer arm included. Diff cover skid plate. Brackets on axle are set up for a 3-link with panhard using Johhny Joints. It is a RHS drop. Disc brakes with lots of pads and in good order. Front is a 29 spline.
Rear is an H233, again numbers indicate ring gear size. Drop out 3rd. Fully rebuilt, everything is new. Loaded with an ARB locker and 4.6 gears. Disc brake conversion, stock was drums. Brakes are all brand new. Set up for a tri 4-link with Johnny Joints. Big thick skid plate welded to housing. Off set a bit to RHS. Rear is a 31 spline.
Both axles have tabs on them for 2.5 Fox air shocks or similar.
Less then 500 miles on both axles. These are perfect for a Samurai or other small truck. These are very similar to Toyota axles. Can also take any measurements you want, will post WMS measurements soon. Will toss in any crap I have for them which came off when they were built. You can get parts for these on Ebay, shipped on over from Australia.
I have nearly $7,000 in the axles, selling for $3,500. You pay shipping from 83001.
pm or call three 0 seven six 9 zero 0 five 9 four
Pictures, steering and suspension junk shown not included.
