I don't remember the part numbers offhand, but I'm running 210 cc injectors out of a V6 Nissan Pathfinder. I also contacted an injector supplier from one of the ebay sellers and he was quite helpful in cross referencing the plug style and sizes ( ppm, etc) so the ones he sent me fit like stock right down to the electrical connection.
On your turbo setup? How much boost are you running with those injectors... and do you have an adjustable FPR?
Only 8lbs, ( but that's easily adjustable) FPR adjustable and set up to 47lbs. The additional alcohol injection allows much more boost and stock timing without knock, ping or overheating. I think I could easily go to 10 lbs but I'm more concerned with the engine internals holding up. Fueling is no longer an issue since adding the H20/ ALC injection, in fact it runs better than it ever did, even after removing the intercooler heat exchanger, no longer even necessary. I'm going to convert the tank and pump from my air to liquid intercooler setup just to store an additional 2+ gals of my injection mix.
