That MS is certainly tuneable, nice to be able to just plug in the laptop and dial it in I bet. Stock injectors are 175. With a 330 you should have all the room you need to find the sweet spot, you'll probably have to up the pressure in the rail though, ya think?
Yeah its really great. My awesome (understanding & interested) better-half does the tuning while I am driving. The biggest problem is not having a way to suck the stock spark maps from the ECM. My curves are just a calculated guess.
The stock FPR must be on a 1:1 ratio. We slowly made our way up to 12psi the other night. I was still getting great air/fuel mixture. I suppose the injector duty cycles could have been above nominal range as well. We only did short bursts/runs over about an hour or so. When I look up the 175cc calculations it doesn't show it supports that much boost.
I am still hoping someone chimes in on what brand/model injectors they are ...or are compatible with. I am going to leave the turbo at the stock wastegate setting until i find injectors.
Right on about the need to restrict the oil to the turbo also
...I looked like mosquito control after boosting heh!
