running high at idle.
  • 957 Views
« on: March 01, 2012, 05:08:37 PM »
i got help to set timing and now the when starts it running high idle. it setting at 2000 rpms. could it be distributor or something else??
Re: running high at idle.
« Reply #1 on: March 01, 2012, 08:16:18 PM »
check your vacuum hoses did you have distributor out? timing belt off? what did you do other than set timing?
« Reply #2 on: March 02, 2012, 03:43:57 PM »
i check all vacuum hoses are hooked up. cam 12 crank 12 and distributor at no. 4 tower. i reset idle screw. i got down at 1000 rpm.  runs great now.
