window
  • 1877 Views
Offline flanny
window
« on: February 27, 2012, 01:21:25 PM »
anyone know how to install the drivers side window. mine was broken when i bought it so i ordered a new one but not sure how to install it
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
FORD 5.0 HO MOTOR WITH TRANNY
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: window
« Reply #1 on: February 27, 2012, 03:09:29 PM »
Sure, your new window should have a metal strip along the bottom of it. Slide the window down inside the door tracks until this metal strip rests alongside the bottom regulator lift. The regulator lift has a flat pice of metal with two holes in it that will line up with your metal window strip. Install the two screws through these holes and your window should be able to raise an lower by turning the window crank.
Hope that helps.... its pretty easy... its probally harder taking the door panel off.
Offline flanny
Re: window
« Reply #2 on: February 27, 2012, 04:49:30 PM »
I took the door panel off the inside but I still have the" door frame" does the window fit in through the top or is there something I haven't removed? What are you calling the panel?
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
Offline WAGON08
  • 78
Re: window
« Reply #3 on: February 27, 2012, 05:17:52 PM »
You don't have any door panels on your Sami
87 sami
30x10.5 maxis mudders
stock 1.3L
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: window
« Reply #4 on: February 28, 2012, 12:30:54 PM »
My 87 has panels with about a dozen push pin style buttons that need to be removed. So does the door pull handle, and the door trip lever bezel.
 It takes me longer to remove the door panel and not break any of the push pins than changing out a window.
Your new window should be slid in through the top. Start the window in from the outside in front in 1st. Holding the window with 1 hand ease it down until you can reach though the bottom to ease it into place. Line up the screw hols and screw in the 2 screws.
Offline Jebers53
  • 1996 Tracker
Re: window
« Reply #5 on: February 28, 2012, 03:54:31 PM »
Not sure about the Sami, but when removing my tracker door panel it helped to take a long skinny flat head and pry out those clips from the door rather then just pulling the panel as the panel slots can tear. Also the door latch bezel had tabs slotted into the door, beware pulling them straight out or they break off, after removing the screw, slide it forward then out the slot.
1996 Geo Tracker 4x4 5 speed manual 2 inch Jeff spacer lift 235/75/15 BFG AT
ZOR front bumper/stinger
2008 Provan Tiger Camper 4x4 on Chevy 3500 HD Duramax/Allison
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: window
« Reply #6 on: February 29, 2012, 02:22:36 AM »
Yes a long flat screwdriver is good (a couple of them. I use a crating tool. It is a two pronged tool that allow even pressure on both sides of the pins.
The door latch bezel is not an issue on a Sami.
