hummmmmm anybody have this happen?
  • 1352 Views
« on: February 27, 2012, 11:36:50 AM »
I'm trying to work out some issues with my new to me samurai. I was able to rebuild the engine and get it running, but when i pull the key out of the ignition it will run for a few seconds without the key kinda strange right? well now im on a little ride and go through a little water not up the the carb but still enough to hit the fan and wash the engine compartment. its still running fine I shut it off in the middle of nowhere and it wont restart. I noticed that my fan which is hooked up to the ignition wont come on and I have no spark. the engine cranks the carb dumps gas but no spark? the fan works when I run a direct wire to it so im thinking ignition switch because the fuses are good the lights work but no spark? please help Thanks Lance
Offline 87Suzi
  • 156
  • Love this little thing!
Re: hummmmmm anybody have this happen?
« Reply #1 on: February 27, 2012, 05:25:47 PM »
I would definately try the ignition switch first if it came down to buying parts. But let it dry and make sure everything is connected before spending any money.
« Reply #2 on: February 28, 2012, 01:36:14 PM »
well I'm going with ignition switch problem. I have power at the switch but not to the fuse box. I jumped a larger white wire on the back of the fuse panel o the ignition coil wire and was able to get power to it. I did not try to start it because I'm a little worried about melting wires. Does anybody have a source for the ignition switch as I don't need the tumbler its working just fine. Thanks Lance
Offline Capt
  • 738
  • 28
« Reply #3 on: February 28, 2012, 04:28:53 PM »
Check your "Fuseable Link" and Master Fuse in engine compartment,
Might have "Popped" while wet.
CAPT
« Reply #4 on: February 29, 2012, 07:44:13 AM »
O.K. so I replaced the switch 60$ ouch that hurt but it does run again so money well spent. where is the main fuse in the engine compartment? I have an 87 I think it might only have the fuse box under the dash. Thanks Lance
