Suzuki Grand Vitara 2.5 ignition coil
  • 1176 Views
« on: February 25, 2012, 01:33:22 PM »
Does anyone know if the screw in the ignition coil (Boot to coil connection) should be sanded etc?
I didn't notice any look of corrosion on the first bank of cylinders I cleaned.
If the screw (or spring for that matter) is specially coated, eg. platimum, you would not want to remove the coating with abrasives - just a light cleaning.
Does anyone know the details?
p0300 p0301 p0302 p0303 p0304 p0305 p0306
Car = 1999 Suzuki Grand Vitara 2.5 V6, 5 speed / stickshift. US version. Flowmaster Series 40 Delta Flow w/ QTP Cutout.
Re: Suzuki Grand Vitara 2.5 ignition coil
« Reply #1 on: February 25, 2012, 01:35:23 PM »
also, the screw didn't want to loosen.
Can or should it be removed, and what happens when it is removed?
